4'' lift: front driveshaft too short: ideas
Discussion in 'The Garage' started by FlatBlackBurb, May 3, 2007.
  1. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    okay so I just put a 4'' suspension lift on my '87 3/4 suburban and we got done lifting it and the front driveshaft is too short by about an inch. should i just get a spacer? ive talked with a bunch of people and they all gave me a weird sideways look and said "4 inches? that shouldn't be a problem". can i stick a grease gun in there and lube it up some? or should i be able to just hammer it out more? how fragile are driveshafts
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Drive shafts are pretty tough but you shouldnt need to hammer anything out. With my front shaft I did take off the dust cap and clean out the old grease that had gummed up in there, that gave me the shafts full travel. the other solution is to have it lengthened. Its not that expensive and makes much more sense than a spacer.
  3. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    alright thanks. ill go try that today
  4. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I'm telling you dude, grease it and see if itll go out more. Dont bother asking again and again without trying that...if it doesnt get a spacer
  5. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    did you drop the t-case?
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    the driveshaft WILL expand more, just have to motivate it too...
    and you DON'T have to drop the t-case on a Burb
  7. 99GmcClassic
    99GmcClassic Registered Member
    Mar 10, 2007
    97
    Abington, Mass
    It will go. I had to heat and hammer mine out, but thats b/c the thing had never been greased before. 4" on sub with a 700r4 needs no driveshaft mods, Im proof
  8. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Same here, on my '89 Burb 4" 700/241 no probs.
  9. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    okay well i just tried it today and it totaly works. just took a little WD40 and some gentle coaxing with a hammer. slipped right in there and works great
