4" lift needs is now 6" lift........
Discussion in 'The Garage' started by victory65, May 5, 2005.
  1. victory65
    victory65 Registered Member
    Feb 1, 2003
    14
    Newberry, Mi.
    First of all, thanks to all who responded to my first question, it's really appreciated. O.K., I've decided to go with a 6" lift to go along with the 35x15.50 Mickey Thompson tires and 15x12 rims I just bought. I know I'll need new shocks, extended brake lines, gear change, steering arm and I'm gonna get the driveshafts lenghtened. I have two questions: 1. After getting the driveshafts lenghtened will I need to use shims to get the angle right for the u-joints? 2. Does anyone know where I can get the proper drive gear for the speedometer?
    I'll post some before and after pictures with the lift and tires and the before and after when I put my 383 under the hood.
    P.S. This is a great site.
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    more than likely, yes.
    no idea, i haven't had a working speedo in years... lol!
    j
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why not go with 1" Zero rates and a 1" body lift?
  4. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    .QUOTE; Victory65 Does anyone know where I can get the proper drive gear for the speedometer?
    As far as i know the speedo gear is a GM dealer part unless you want to order online ..... Your local part store probably wont have it... Here is some info i found doing a search for '' Speedometer drive gears''
    http://www.tciauto.com/tech_info/speedo_gears.htm
    http://www.transmissioncenter.net/speedometer_calibration_______va.htm
    I don't no what kind of motor,tranny, or transfercase your running but i hope this helps get you started in finding some info....
  5. victory65
    Feb 1, 2003
    14
    Newberry, Mi.
    Thanks to all for the info.
    And thanks Mudslinger99 for the sites you listed. I'll no doubt have many more questions as I continue with this project and I'm glad to have this community to "lean" on.
    Thanks again,
    Rob (victory65)
  6. victory65
    Feb 1, 2003
    14
    Newberry, Mi.
    What are 1" zero rates
    I've never heard of that before?
    Thanks,
    Rob
  7. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    zero rates are simply blocks of steel that are added to the bottom of a spring pack which provide lift without effecting the spring rate (hence the name). I have run them at various times in both my front and rear axles with no issues.
    j
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    also important to not that they are not simply blocks, they become an integral part of the spring back when installed. conventional blocks in the front are illegal in all 50 states AFAIK.
