4" lift needs.......
Discussion in 'The Garage' started by victory65, May 5, 2005.
  1. victory65
    victory65 Registered Member
    Feb 1, 2003
    14
    Newberry, Mi.
    I just got a 72' K-5 Blazer and I want to install a 4" lift to clear a set of 35x12.50's. My question is will I have to do any driveshaft modifications?
    Also, should I install a new steering arm? I'm already planning on installing braided brake lines and changing the ring and pinion gears.
    Any help or advise would be greatly appreciated.
    Rob
  2. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    OK with just a 4in lift you should not have to do any driveshaft mods. You will need a drop pitman arm and shocks to complete your 4in lift.
    Hope this helps
    later
    jmd
  3. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    I preferr the raised arm over a dropped pitman arm JM .02
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Likewise.
  5. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    depends on the springs... I have about 4" of lift and need way more slip in a driveshaft than any factory one provides...
    j
