4" lift on a 1 ton
Discussion in 'The Garage' started by shaun, Jun 3, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    So I have these 4" TC ez ride lift springs from the front of my jimmy (from before the 57's up front swap) and I have this stock 86 chevy 1 ton. So i decide to put my 4" leaf springs underneath the 1 ton. 2 hours later I set her down on the springs and I deffinately dont get 4" out of it. How much difference is the spring rate between 1 tons and 1/2 tons. I think I got 2 or 2.5 " out of it (it is a new lift) but it is hard to tell with no bed.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    When I was shopping for kits for my crew cab every brand I checked used the same part number front springs for 1/2, 3/4 and 1 ton. Only the custom spring companies (Alcan, Deaver, etc) offer something different.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    what engine do you have in the 1-ton? bumper? winch? sounds like the front end of that rig is just heavier than the front end of your other one. I know on my rear 52s, when I used to have the top on, my shackle flip gaveme like 3" of lift... without the top on it was like 4.5". lol.
    j
  4. shaun
    Apr 22, 2003
    745
    I have no bumper or winch. I do have a 6.2 in it instead of the 350 in my jimmy. It may be 3" but it just doesnt look like it. Does anybody with a 4" lif have measurements from rither the ground to the frame or body or maybe how much fender gap between the top of the tire and bottom of fender.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    that is prolly the difference right there.
    ez rides are pretty soft springs, adding weight to the front end is going to cause them to squat more than springs with a higher spring rate.
    j
  6. shaun
    Apr 22, 2003
    745
    Thats what I figured thank you sirs
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    with my blazer with 4" and 35s (actual size of tires is 34") my bumper height was 25" up front (bottom of bumper to flat ground)
    hope that helps. i dunno if it does or not
  8. shaun
    Apr 22, 2003
    745
    It does thanks alot
  9. rockspider
    rockspider Registered Member
    Sep 9, 2004
    37
    I have a similar problem waiting to happen, and hope you can help me.
    Sorry in advance for the long post!
    My rig is an '85 M1028 CUCV, so something very similar to your '86 1ton.
    It's a 6.2 with Dana60 front, with the stock bumper and hooks.
    When I bought it the ride height was really saggy, but being on a tight budget and having some more important items to spend on to have the rig going, I went for a leafs rearching.
    I noticed that the front spring pack has three leafs compared to my friend Blazer, and when I rearched them it gained enough lift to clear 35"Bfg on 8.25 steelies, without any trimming. (only other mod I have built 1" longer shackles)
    And after one year of daily driving it hasn't sagged much. Wondering if the springs under there were stock or not...
    BUT the ride even on the most milder offroad trail is harsh, almost no artic.
    So I'm convincing myself that I need a real spring set.
    I would be happy with the lift it has now or just barely more, don't plan on using anything more than 37"x12.50 due to road laws here in Italy (Europe) but have no idea of how much lift do I have now. (and there aren't many of these trucks here to compare...)
    I don't want to buy, say, an EZ4" and find later that it lifts the rig less than it's now!
    How do I tell how lifted is it now?
    Can anybody take a measure of a 4" or 6" lifted diesel 1ton from under the frame to the top of the spring plate, in order to have no variables from different thickness springs or different height tires in the scenario?
    Which spring will work well in a diesel 1ton for dd+offroad use?
  10. shaun
    Apr 22, 2003
    745
    I am going to put a 3" 56 lift spring up front. This should give me 6" or I will put a 4" but I am not sure yet I want to see how much this 4 " is actually sagging
  11. rockspider
    Sep 9, 2004
    37
    SeventyK5 please can you take for me a measure from top of the milled spring perch to the bottom of "C" frame with those 4" lift springs front, just to make a comparison?
    Our 1 tons share the same powerplant so the weight up front should be equal.
    This would be very useful to select the necessary lift.
  12. shaun
    Apr 22, 2003
    745
    I can do that
  13. rockspider
    Sep 9, 2004
    37
    Please, any news for that measure? I really need it!
    Thanks in advance
  14. shaun
    Apr 22, 2003
    745
    Wasnt able to make it out to my truck and wont be able to until thurs or possibly fri.
  15. shaun
    Apr 22, 2003
    745
    I went from the top of the ubolt plate to the frame and that is 7.5 from the raised center or 8" from the edge of the ubolt plate to the bottom of the frame. I then measured from the bottom of the front bumper to the ground and got 23.5" w/ 265's (31's?). This means that the lift doesnt sag at all being mudbuddy got 25"s with his blazer having 4" lift and 35's (which measure 34") MAybe it just looks wierd after thinking the custom suspension on the jimmy was 6"s. Oh well. time for 56's front and 63's rear. Thank you all
  16. rockspider
    Sep 9, 2004
    37
    Thanks for the numbers!
    I'll check them and compare with my truck.
    I was thinking about your comparo with Muddybuddy numbers, but if he has a Blazer with 10bolts axles then it means your springs sag quite a lot! Given the difference in tube diameter between 10bolts and a Dana60, and the thick spring perches on the diff side, a 10 bolts with 34" has about the same height from the ground (at the top of the perches) as a stock Dana60 with 31,5" (235/85R16 were that high).
    This means that with the 6.2 the heavier front made the spring sag a full 1,5"!
  17. shaun
    Apr 22, 2003
    745
    I figure between 1 to 1.5". But it is an 1000 lb motor as compared to 450 for a sbc.
  18. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    hmmm wish I knew that.. I wouldnt have gotten my superlift soft rides... :crazy:
  19. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    dont worry I have superlift softrides and would could drop a cummins in there and they wouldnt move
  20. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    Front springs on my M1008 K30 with 6.2 are really bad now. Having a ramsey 15000 up front doesn't help much :D
    I'm planning to go with either a TC Heavy duty or a Rancho.
    Walter
