4" lift with 37s?
Discussion in 'The Garage' started by wy4tt, Apr 22, 2005.
  1. wy4tt
    wy4tt 1/2 ton status
    Feb 20, 2005
    153
    USA
    Right now it has a 4" lift and 35s with some minor cutting. I'd like to get some 37" under it. Are any of you guys running this combo with luck, and did you have to cut a lot? Thanks for the info.
  2. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    Ran it on an old rig (sorry can't find any pics) with quite a bit of trimming. I now have 4" springs and a 2" body with P.J. dirt grips 36x14.5x16 and I'm breaking out the tourch tomorrow for some "minor adjusting" :weld: :hack: :grind: :burb: .
    If you take your time you can make the cuts look good.
    Try a search on fender trimming, there were some good post's (with pics) within the last couple of weeks.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Trim your fenders, it does look good in my honest opinion. You may want too add a ORD 1" body lift, and Zero Rates too relocate the axles. That inch to inch and a half makes a big difference.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I run 13/38-16 TSL's on 10" wide rims with 4" of lift and no axle relocation. I had to trim quite a bit from the rear of the front fenders, including pounding the firewall seam flat, but they just barely rub under full stuff and when turned.
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Well, the pic below is 6" and 39.5's with lots of trimming. However, if you do the trimming right I think it can look pretty good. I don't think you'll have to relocate the axle with 37's but I could be wrong. IIRC there's a member around here that's currently running the exact combo you're looking for. Give it a little time and hopefully he'll post up.
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i run a 38x15x15 Gumbo mudder with 4 inch lift chopped fenders and no axle relocation, i get rub on firewall in fron but under pritty good flex
    LUKE
  7. wy4tt
    Feb 20, 2005
    153
    USA
    Thanks for all the posts guys. Looks like I'll have to do some more trimming. I don't have a normal pic of it posted yet, but here's a photoshop bit that would give you guys an idea of where it is now. I photoshoped this to get at a family member with a Rubicon. This is with 35s. Thanks again!
    http://users.adelphia.net/~wy4tt/
  8. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Very good lookin trim Mikey!!!!!!!!
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here is mine with 5" and 37x12.50's on 15x10 4.5" backspacing. It is actually about 4" with my winch and 4 yr old springs. I didn't have to cut too much, but my axle is and inch forward too. Rubs a bit on the inner fender.
  10. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Here's my trim job.....as well as my aggressive 31/10.50R15's :D
  11. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    37x12.5x15 with 15x8 wheels about 4"bs. 2.5" lift.
    The wheel is mostly stuffed, but not completely:
    As you can see I need much trimming. I do plan to go up to 4" springs in the back and a 1" zero rate in the front. When I have the stuff together for crossover, I'm probably moving the axle forward 1".
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Here is mine from the side, I also cut everything off in the fron under the rad support. only rubs a bit on the inner which could be fixed by bending it back. :D
  13. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    are there any first gens out there running this setup? any pics? thanks :bow:
  14. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Ok, well I had some pictures on here but they seem to have been deleted somehow. Anyways, im running about that exact setup. (A 5.75" shackle flip in the rear on stock springs, and 4" bds springs up front with a 1" zero rate). It equals out to about a 5-5.5" lift. Im also running 37x12.5x15 Goodyear MT/R's. It didnt rub going straight or turning, but even pulling into the driveway made them rub. Wheeling without first cutting the fenders was trouble. At one point, when I was testing the flex and looking where to cut, I got so flexed out in 2wd (detroit rear so I had plenty of traction), that the truck cut off because the tire was jammed into the fender so hard. I had to re-start and put it in 4-lo and just let the truck "re-locate" the fender for me. I dont recommend it though, as it also almost ate my tire. :doah: Anyways, I had to cut quite a bit. In the front and rear. The fronts rubbed so bad that I also had to cut and beat back the inner fenders.
    So, yeah, your gonna have to cut considerably if you actually want to wheel it.
    -Harrison
  15. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    that good sir is a really REALLY nice lookin truck. kudos :bow: :bow: :bow:
  16. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Awesome hack job!! Love the lines and curves,
