4" lift
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Aug 8, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    4\" lift
    i am considering going with a lift. don't really need the hight just wider tires so i may go with a 2", but then again you can't really go high enough. what mods are required to the driveshafts(both front and back) on a 4" lift??
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    Re: 4\" lift
    just put the 4" in thats all you have to do man i have a 4" with 35s no rub
    can some 1 find me a ford i need to take a pee k5s kick a$$ still peein on that ford just have to keep goin dam i can not stop pissin:)
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Re: 4\" lift
    My buddy's red '72 is currently using the stock front driveshaft, but it gets over-extended when he droops the suspension fully on the highway (when cresting fast rises). He is running a longer rear driveshaft than stock. I'm not sure on the measurements...
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: 4\" lift
    To doit right new driveshaft would be in the best thing to do.
    also a steering arm is needed to keep that drag link parallel with the ground. Brake lines and such shouldn't be much of issue at most the front brackets would be relocated to the bottom of the frame rails.
    Good Luck
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
