4 LINK LATTER BARS TRACTION BARS whats the difference?
Discussion in 'The Garage' started by CHEVY 4WD, Nov 4, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    The title says it all
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Someone correct me if I'm wrong, but this is my understanding:
    4 Link - necessary in a coil-spring setup, two bars connect to top of axle, two connect to bottom. These hold the axle in the proper place and prevent it from twisting (axlewrap type twisting)
    Ladder bars - same basic idea, bars connected to frame and axle, but generally there are only two. These also prevent axlewrap. Ladder bars are seen in leaf spring applications, too, because they aren't necessary for locating the axle.
    Traction bars - these are little blocks mounted under leaf pack (sandwiched between axle and leaf spring) continued backwards and then bars connect up to the leaf pack (sorry, it's hard to explain in words - try a search, there were pictures posted not long ago in the Garage) Anyway, these also prevent the axle from wrapping when hooked up properly.
    Hope this helps and all the info is accurate.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    3/4/5 link and similar systems actually locate the axle and the springs (coil/coil-over/1/4 elip/etc.) just support the weight. Traction bars normally do nothing more than keep the axle from twisting leaf springs into an "S" shape resulting in physical damage and/or wheel hop along with other problems.
