4 link suspension
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bad_bo_ti, Sep 23, 2000.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    Can anyone tell me what all i need to 4 link my blazer, is i something i could handle or leave it to an expert, let me know where i can get the parts too. thanks.
  2. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    I'll take a stab at this because I'm working on the same thing. First of all, you've gotta ditch your leafsprings. You will need to use coils, coilovers, or some kind of quarter-elliptical leafs. You would use 3/4" or 7/8" heim joints (also called spherical rod-ends) on the end of all of the links. You will need 5 links per axle if you do a 4-link w/panhard or just 4 for a "true" 4link (triangulated upper links, no need for panhard). You should also use limiting straps and bump stops that actually work, too. You can design and fabricate it all yourself if you are a good welder and have some smarts. It's actually very easy to understand. The best thing to do is make a model with 5/16 cheapo rod-ends from summitracing.com and see for yourself how it works!
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
  4. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
  5. Donovan
    524
    Arvada, CO
