4-Low
Discussion in '1992-Present Chevy & GMC models' started by RacerHead, May 29, 2002.
  1. RacerHead
    RacerHead Registered Member
    Mar 30, 2002
    24
    Dallas, Tx
    I am having a little problem, when I lock in to 4-Low its starts to move then slips like crazy then it will catch all of a sudden.
    It does not do this is 4-Hi. Do i just need to rebuild it ?
    It's in a 94 Chevy Suburban K1500 with a 4inch Rancho lift. 305/70/16 ProComp A/T, 4.56 gearswith a aurburn limited slip The tranny is a 4l60-e, TC is a NP241.
  2. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    I had a friend that had the same problem and it was a snap ring or lock ring on the main(output) shaft that had broken or come off.Not sure exactly which one it was cause i didnt get to see it but its an internal problem for sure.......Also check to see if your shifter is out of adjustment!
