4" or 6" lift for blazer?
Discussion in 'The Garage' started by JUNIOR-K5, Mar 27, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    Just want to get some opinions should I get a 6" lift for my blazer for my 38 boggers or keep my 4".If I remove the 4" and go with the 6" ill put the 4" in my suburban since it has a 2" now.I currently have a 4" sus. lift with 2" body lift.
  2. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    just depends on what your gana use it for i guess. mainly mud ide go with the 6 but if its anything else off road ide go with the 4.
  3. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I would think to run 38's you are going to need 6" minimum unless you are going to shave some sheet metal. Any less of a lift and you will be bendig sheetmetal with even a little suspension flex.
  4. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    ya i had 38's on mine for a while they did rub a little if you hit a hole purdy hard but i did a little triming underneth . i would say go 6 you could allways add like 1 or 2 inch body lift to it but i dont really like body lifts . :D
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I say go 4 and trim. Here is mine on 4 with 37s.
    Ira
  6. JUNIOR-K5
    Dec 20, 2005
    387
    SO.CAL
    It will mostly see mud and trails no rocks.I think ill go with the 6" lift and put the 4" in my sub.Im looking at the tuffcountry hd 6" springs for the front and dyi flip with 6" shackles and add a leaf will that give me 6" in rear.I dont really want to buy 2" springs for rear how else can I get 6" in back.Thanks:D Sandawgk5 thats a sweet blazer I just dont want to cut that much thanks for the pix.
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    search over at pavementsucks.com in the for sale section as a guy has front 6" superlift springs for sale... think $110 or so.... if you are not perticular to the tuffcountry hd:crazy:
