4" or 6" lift K10 Longbed
Discussion in 'The Garage' started by Cricket, Aug 7, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Which lift would you recommend, 4" or 6" for a 77 longbed pick-up? What brand do you prefer?
    Right now it's on 2.5 Ruff Country and 33's. I am in the market for more lift. This truck will have to be streetable and handle moderate difficulty trails.
    Seems like once you get over a 4" lift you really start changing things in the steering, driveline, center of gravity, tire size, trimming et.
    Any other guys out there running the trucks?
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i had 4" o.k. no real problems. then went 6" only big problem was front shaft grinding. had th350 with 205 setup. also complet ord stuff for it. like poly geasable bushings hd shackles flip 4" rear ya know all the good stuff. had 3" body lift and 38x12.5x16.5 tsl on 9.75 rims and would stuff then in to the fenders at full flex. all of this on 1/2 ton frame and d60/14ff setup.
  3. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    i have 82 long box 6.2 with 4'' tuff county ez-rides all leaf spring set up flexes good and rides smooth.it has 35-12.50s .no changes to steering, brake hoses and drive lines.
  4. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    82 k10 longbed 6" superlift and 56" 6" rancho outback gonna put my 52" springs up front 35x12.50x15 bfg muds
  5. Iron_Weasel
    Iron_Weasel Registered Member
    Mar 29, 2005
    70
    New Mexico
    Not to hijack......
    I ws kinda wondering the same thing on my 79 K10 LB.
    From reading the other replys, it looks like 4" and less *usually* doesn't require and major modifications.
