4" or 6" Lift?
Discussion in 'The Garage' started by Bart Reid, Mar 31, 2006.
  1. Bart Reid
    Bart Reid Newbie
    Mar 31, 2006
    4
    Valley Center, CA
    I have a stock 1990 K5 and I am putting 35" tires on it. Do I need a 6" lift or will 4" suffice without any body mods?
  2. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    i am almost positive a 4" lift will fit 35" tires. a rough country kits recommended tire size for a 88-91 blazer is 35" so ya it should.
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    4" should clear 35's just fine. You may rub your fenders if you get it really flexed out or have a really flexy suspension, but otherwise you should be ok.
    -Harrison
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I had a little rub with 5" on the Burb, but it self corrected the fenders and all is well.
  5. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Im going from a 4 inch to a 6 inch lift because I wanted to clear 35's. I had the superlift 4inch kit and it looked to close to me for 35's. but that may be because I worry too much about my fenders. What will a 6 inch lift fit then?
    ~Brian
  6. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    most of the time on a six inch lift they tell you that the recommended tire size is 35". but on cardomain ive seen some suburbans on 37" and it didn't seem like they trimmed anything or chopped up the fenders. as far as the ride might go idk. all ive had are 35's and im trying to lift my 6" to an 8" before i even think of 37's or 38's
  7. willymonster
    willymonster 1/2 ton status
    Feb 18, 2006
    183
    PARADISE,CA
    i would do the 6 :D
  8. goldwing2000
    goldwing2000 Guest
    I've got 35s and a 6" and haven't had it make contact yet. Comes close sometimes but no grindage.
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    6" and 38's!! haha. I had to trim if i wanted to go offroad. But i could drive with no trim. Only times i hit was highspeed speedbumps and jumping a curb at 35mph.
  10. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I have a rough country 4in lift and 35's mounted on stock wheels. I dont rub at all. I havent tried to flex it yet though.
  11. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    you can run 35's on a 4". keep your sway bar hooked up in the front. that will keep you front tires from rubbing. even if you do go with the 4" and dont like your flex, throw a body lift on it.
