4" ruff country front drive line wont fit!
Discussion in 'The Garage' started by BiggerRigger, Jul 29, 2005.
  1. BiggerRigger
    BiggerRigger Registered Member
    Nov 3, 2002
    81
    C.D.A. Idaho
    As the title says My front drive line is about an inch to short. Is this common on this kit and is there a fix or do I need a new front shaft?
    Aaron
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    When I did a 4" lift on my K5 about 6 years ago it was long enough. I had to grind on the driveshaft so it would droop down enough and have full articulation. Sorry, dunno what to tell you.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Unusual. I just did a 4" TC lift on 1 K5 and a 5" on another with no length problems. My only concern was that the front shaft hit the exhaust, and the exhaust had to be rerouted.
  4. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,008
    609
    Pueblo, CO
    I put a 4" rough country lift on a few months back on my K5. No problems with the front driveline. In fact we never even removed it when installing the lift. Just dropped the axle onto jackstands and supported the frame with a large pnuematic bumper/frame jack. I had enough length on the slip portion of the shaft to address the new postion of the axle.
  5. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Have you pulled on the shaft to extend the slip? Probably stating the obvious, but the driveshaft does extend and colapse you know. ;) Also is the suspension at full droop or is it sitting on it's own weight compressing the springs?
  6. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Ditto
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It should work fine. I put a 6" Rough Country kit on mine and the d-shaft was long enough.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Mine was alittle rough to get everything to "connect" but with alittle "help" with getting extended to where it needs to be, it will fit..
    As i mentioned, mine was abit rough, i thought because it had never been that far out and needed alittle coaxing.
    Grease it up, slide back and forth, pull it out,,,,,, :thinking:
    That just doesn't look/read/sound right there.......
  9. BiggerRigger
    Nov 3, 2002
    81
    C.D.A. Idaho
    I tryd every thing I can think of to make it fit and nothing! I put the shaft in a vice and pulled pushed from one end to the other and it is just to short. At full drop it is over an inch to short. The only way I see to make it work is to
    A. get a longer shaft
    B. Machine a spacer to fit inbetween the transfer output and the cv mounting flange.
    Is there something Im missing here?
    How much movement should there be in the slip yoke on the drive shaft?
    Aaron
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You should be able to take it completely apart.
  11. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    This is a subject that I have never found the answers to be the same.. It seems like what works for one truck dosen't work on the same truck for somebody else..
    Here is a good example.. We put a 6 inch lift on a 86 Blazer and the driveshaft is fine.. We put a 4 inch lift on a 89 Blazer and it needed to be extended.. Both with 35 inch tires..
    Here is another example.. We put a 4 inch lift on 85 Chevy 1/2 ton and the driveshaft was fine.. Now I'm going to put a 6 inch lift on a 84 Chevy 3/4 ton and I'm going to need a longer driveshaft.. Both with 36 inch tires..
    So I don't think there is a one answer fits all in this situation..
  12. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My question also. I never disconnected mine whenI did my 5" lift. No problems except for the y-pipe getting it the way.
  13. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I put a 4" kit in one of my trucks and the drive shaft ended up being too short. I bought a 1" spacer that attached to the transfer case output flange. It solved the length problem and has worked well for the past couple of years. I found it by posting in the Parts Wanted section.
  14. BiggerRigger
    Nov 3, 2002
    81
    C.D.A. Idaho
    Thanks for the replys guys. It looks like im off to fimd a spacer
    Any one have one for sale?
    Aaron
  15. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Try superlift, I can't remember the part number, I want to say 4130 but don't think it is right, anyways the have for like 30-50 bucks.
  16. Storm Trooper
    Nov 24, 2000
    4,640
    Depending on what you have, they do make longer yokes also.
  17. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    You might want to check some local driveshaft shops to get my front lengthened they charged me 120 will all new U joints its only like 60 buck with out the u joints
