4" shackle flip vs. lift springs
Discussion in 'The Garage' started by R72K5, Mar 10, 2006.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    uhmm i am contemplating a lift on the 77
    but i am unsure which would be better/more economical
    shackle flip, or lift springs
    and also considering possibly having to buy drop pitman arm and longer hoses
    if i go the springs route then whats the best deal on springs that would be good ride for street only/mainly ?
    if i can get either kind of a kit for around 250 or 300 then ill probably do it right now
    it was either that or cut my fenders so the 33 x 12.50 clear better when turning instead of eating the fenders like they do right now
    any links would be great, to kits, info pages, prices, etc
    thanks for anything!
  2. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    if your back springs are decent, a flip will be more economical... gonna run ya more than 300 tho for a flip and new front springs.. front springs are running $225ish, flips run $175ish, rear springs'll run ya $350, $375 if ya go that route...
    Kert at http://diy4x.com/ flip has been real popular lately... or you can always go ORD for one stop shopping.. might wanna peak at ORD to get an idea on prices for springs, hoses, steering, etc.. http://www.offroaddesign.com/
    for a street driven truck, i'd definitely go with a flip over spring lift... throw some tough Country EZ rides up front...
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Never find a spring lift for both axles for $300. Double that figgure and you maby can get close.
    Shackle flip either. Unless you flip your stock ones (see CK5 tech article) Shackle flip is aprox $200 then you will need front springs, shocks, steering arm ect $300+
    For 300 your only option besides home made shackle flip is blocks in the back and springs in the front.
    Rough Country has about the cheapest lift kits. Some here dont like them. And I admit the rear blocks and front spring lift ride very stiff espically on old wore out stock rear springs.
    But I like their full suspention lift with front/rear springs and nitro shocks. It rides good. They are a good all around lift for street, trail use, and towing. I bought a Rough country lift cuz I called Tuff Country and they did not recomend I use their EZ ride lift because I tow with my K5. They said I needed heavy duty lift with higher rate springs. So I saved about 300 bucks by buyng Rough Country
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I waiting for someone to use the "S" word.
  5. goldwing2000
    goldwing2000 Guest
    Stuporlift?
    I went through this dilemma a little while ago. My stock springs are shot, so it's going to be cheaper for me to go spring lift.
