4 spd swap... 1 last question (hopefully!)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Mar 8, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Does anyone have or can get a pic of where the clutch rod comes thru the floor/ firewall to attach to the pedal? Or even a description of where it comes thru. I am possibly putting it in tomorrow and thats the only thing I am not sure of. Is there a hole or a scored area where it will come thru or is it going to be up to me to locate a spot?
    Thanks.
    Mike
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    it goes to the left of the brake pedal-..
    im just goofin- if you still need a picture in the morning let me know- my cameras in my truck- but ill be doing the brakes first thing
    Brandy
  3. Thumper
    1,582
    Alberta Canada
    Hmmm are you sure its to the left? /forums/images/graemlins/rotfl.gif
    Ya know... maybe instead of MUDNURI, your name should be SMRTASS!
    \Hehehe
    I may need a pic, but will be leaving here around noon, so maybe someone can get me one up by then?
    Thanks!
    Mike
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I remember tryin to figure out exactly where to cut the hole in my floor. It was one of the last things I did. Had EVERYTHING else hooked up and installed except the rod that goes through that hole. Do you have the bracket on the frame for the swing arm from the bellhousing? Once you have that bracket on the frame, and the swing arm thing installed, you'll get a better idea of where the hole needs to be. Just look at it from the bottom...It'll make more sense when ya see it with your own eyes. Hope I didn't just confuse ya.... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I ended up w/ a hole about he size of a BIG coffee can... I just covered it w/ rubber from an old innertube. I would send you a pic of it, but you can probably figure out how to butcher your floor like mine all on your own /forums/images/graemlins/shocked.gif
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i just removed the little panel that was there.... but i bet you dont have one of them...
    /forums/images/graemlins/angryfire.gifgrant
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    I don't have a pic but I measured mine and it's about 13.25 inches from the kick panel, about 12 inches from where the floorboard starts to bend up toward the firewall and about 2.5 inches below the joint where the floorboard and firewall meet.
    Hope that helps a little.
  8. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    mine didn't have a little panel. I burned the teeth off my hole saw, so I chopped mine out w/ a chisel and a hammer...
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i would get a pic of my 79 but it is 20 miles away and i have no vehicle. I could get a pic in a couple of days thought. its the best i can do
  10. dyeager535
    26,979
    No it won't have the scored area, because the '85 was setup for the hydraulic clutch, and if you look up on the firewall, you'll see where the clutch master cylinder is supposed to be.
