4 Spd. to TH400 (what about kickdown operation)
Discussion in 'The Garage' started by Scott A, Jun 10, 2004.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    The previous owner installed the TH400. I noticed there is no wire that should be hooked up to the kick down connector on the driver’s side of the transmission. Don't I need to get the gas pedal kick down mechanism from an original TH400 truck, and then wire it to the transmission?
    UPDATE: I went to the junkyard and found the switch and all the wiring out of a 79 Suburban with a TH400. It bolted right in, one wire to the fusebox the other to the transmission and I am all done. /forums/images/graemlins/cool.gif
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Put it on a button on the steering wheel. Just needs 12v and when you want to pass push and hold the button.
  3. lason
    lason 1/2 ton status
    May 31, 2004
    105
    Arlington TX
  4. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    I think I will just look at the Junk Yard for a factory TH400 kickdown pedal. I guess any 73 and up, Suburban, Truck or Blazer will do, that originaly came with a TH400. Should I grab the whole pedal? or is this a separate electrical part that attaches to my exsisting pedal or firewall??
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What does this kickdown thing do? /forums/images/graemlins/confused.gif
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I have a 400 equpped truck that is going to scrap where is the switch at?
  7. dyeager535
    26,976
    Bolts to the pedal assembly or floor somehow...can't recall how, but when I pulled one some time back, I didn't grab the pedal, so I don't THINK it was a special pedal assembly.
    Works pretty much like the brake light switches as I recall. Very simple at least.
  8. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    The switch is down by the gas pedal.
    What does it do:
    (It kicks the transmission into 2nd gear with you step on the gas all the way.)
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    oooh okay. Thanks /forums/images/graemlins/thumb.gif
    Sorry for the hi-jack /forums/images/graemlins/doah.gif
  10. mrk5
    Apr 20, 2004
    12,330
    1,038
    Northern Colorado
    Here's a pic of a factory setup. Electrical connection on the left. To the right is the slide switch. As you depress the pedal the rod above the pivot point at the bottom of the picture comes toward you and contacts that brownish peg poking out to the right. The switch is just bolted to the pedal brace there. Should just need the switch and I'd guess it will bolt right in.
