4 Speed Mount Fab
Discussion in 'The Garage' started by Cricket, Jan 11, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    This may not be the best place to post but:
    Can one of you guys fabricate the 4 speed actuator lever bracket. That is the bracket that mounts to the frame. The lever mounts to the frame and the bellhousing.
    I'm in the middle of the auto to manual swap and need the bracket. If someone has a loose bracket lying around that would work too.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Are you talking about frame bracket for the "Z" bar for the manual clutch linkage ? If you are asking about the bracket that mounts to the frame with two bolts and the "Z" bar has a side stud that goes through it than it is less than twenty bucks from your local GM dealer .
    HTH's , Tom
  3. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Ya, that's the pieces.
    Thanks, I'll go down and peruse the local merchant. We got a pricey parts dept. but I'll check the bendover angle.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if 2wd will work then ill have all the pieces soon, from my 84
    good luck
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Frame Bracket for 4 speed linkage
    Here's a picture of the bracket, over to the left. I have all the z bar stuff, just didn't get the bracket from the guy that sold me the parts. Being new to 4spd it never crossed my mind to ask. If you have one of these I need it.
