4 speed shifter slop(pic)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyguybc, Nov 2, 2006.
  1. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    heres a pic of the shifter retainer, you can push and remove it.. but the hole around the shifter rod seems a bit ovalized for my liking.. resulting in alot of slop...... you guys know if that gap is normal or should it be tight to the shift rod
    so do i buy a new one fro lmc or whatever
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That is not why you have the slop, the slop comes from inside.
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah look at the area on the other side of that hemisphere. there are a couple tack welds in there that are prone to breaking and causing a lot of slop.
  4. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    tack welds where,on the retainer?
  5. dyeager535
    26,980
    Just pull the shifter out and look at the end of the shifter. There are rubberish rings that fall apart, and the tack welds as previously mentioned. Also a few posts about these problems w/pics.
  6. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I believe there is a write up on Pirate in the tech section.
  7. Alex_B
    Alex_B Registered Member
    Feb 28, 2006
    33
    Newfoundland, Canada
  8. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    thanks for the tips guys, i guess the word hemisphere through me off
  9. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    sure as shat i poped mine out as i am doing major body swap work. and i read this along with the posted link info. and i to have more work ahead of me. mine was broken at the welds. :doah: oh well i like playing with the welder. :bow:
  10. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i re-welded mine and used new o-rings from the hardware store and its all tight again:D
  11. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    well turned out my roll pins were half worn through. but the welds are great and the area where the roll pins seat are fine, im happy with how much slop it has now, if you shake the shifter a little, you can feel it go into reverse
    im happy! now onto the clutch/flywheel motor, 63s, and rear driveshaft and shes back on the road,lol
  12. sweetk30
    Nov 1, 2004
    25,548
    543
    whats the o-rings for? :confused:
  13. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    was wondering myself
  14. dyeager535
    26,980
    They aren't actually o-rings from GM, the pieces I removed from mine appeared to be square cut.
    I haven't looked at a shifter I can't recall what GM used them for, probably somewhat vibration control and somewhat for tightening it up a bit.
  15. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    pictures please of this square ring, not an o ring then is it..
  16. dyeager535
    26,980
    All I got out of mine were some reddish chunks of hardened rubber. Most of the "ring" was gone when I pulled it.
    I've got a newer trans in the garage, maybe it's still got something I can look at closely.
    Apparently the right size O-rings will help, but I suspect the GM pieces were a fair bit harder than the average o-ring.
