4" Springs + 4" Flip, Pinion Angle?
Discussion in 'OffRoad Design' started by Hardcore, Oct 9, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    4\" Springs + 4\" Flip, Pinion Angle?
    How close is the pinion angle for new 4" rear springs and a 4" ORD shackle flip?
    I'm rebuilding my 14 bolt and want to move my spring perches. I'm wondering if I can put them at the same angle as stock?
  2. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Re: 4\" Springs + 4\" Flip, Pinion Angle?
    Tack weld them in the stock location and try it out under the truck with the t-case setup you're going to run for good. I suspect you're going to want to have a CV jointed rear driveshaft so you'll want the pinion pointed at the t-case and the susp. combo you're asking about should come pretty close to doing that.
    BUT, don't take it for granted, just do a test fit and find out for sure.
  3. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Thanks Stephen /forums/images/graemlins/thumb.gif
    What should I use for the spring perches, reweld the cast ones back on or do I need to use new ones, if so where can I get some?
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    We've re-used the factory perches before, we're also working on a new perch for it, just some details to finish on it. It'll be 2-3 weeks yet.
  5. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    2-3 weeks = /forums/images/graemlins/thumb.gif
    Thanks again /forums/images/graemlins/thumb.gif
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I haven't been in any of the lafyatette shops lately but i know the local BR 4x4 shop had spring perches in stock $20...I reused my stock ones once but screwed them up the second time so bought new ones...
  7. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Which shop? Light Line?
