4" suspension plus 3" body lift?
Discussion in 'The Garage' started by silver, Jun 9, 2002.
  1. silver
    silver Registered Member
    Jun 8, 2002
    72
    Dallas Texas
    4\" suspension plus 3\" body lift?
    i have a 4" suspension lift on my 1970 blazer and i'm thinking about adding a 3" body lift, will i be able to fit 35's without any fender trimming?
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Re: 4\" suspension plus 3\" body lift?
    Don't quote me on this- BUT I have a 4+3 and I can, mine's an 86, so who knows..I guess it has a lot to do with the condition of the springs etc.. how saggy your truck is and that sort of thing. do a search on "What tires will fit" and you'll be suprised at the contradictions! Just don't get upset if someone says they will fit, and they don't,,, or vise versa, that's happened before too!
    Brandy /forums/images/icons/grin.gif
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have 36's with a 3" body lift. I did some major fender trimming though and with MAJOR flex it will rub
  4. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I got 4 + 3 on my burban, I put on my buddys 35s and they rubbed up front due to turning and articulation.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Part depends on the wheels and tires not all 35"s are really 35"s tall. And the back spacing and width of the wheel has some to do with it. Also depends on the width of the front axle. 3/4 ton front axles are wider than 1/2 ton fronts. Then the other thing is how and where you drive it. A bolevard crusier will get away with stuff that a real off road truck can't cause it don't get all crossed up like a trail rig might. /forums/images/icons/cool.gif
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I have a 4+3 on my 82 with 35/15.50/15s .
  7. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    go with shackle flips or add-a-leaf, bodys are cheap and easy but can me difficult and cause problems.
  8. silver
    Jun 8, 2002
    72
    Dallas Texas
    i have a dana 60 in front with a 14 bolt in the rear. i go offroading whenever i can but it is also my daily driver. any advice on how to fit 35's with my existing 4" suspension lift?
  9. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    do you want to trim?
  10. silver
    Jun 8, 2002
    72
    Dallas Texas
    no trimming, my car is beautiful... not a junker.
  11. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    just curious as to what are the major problems associated with body lifts. Everybody always says go suspension, but what is the big problem with body lifts? I understand they aren't going to help flex, but they do get the body out of the way of the meats.
  12. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    doesnt have to be a junker to trim, you can do a very nice trim job like project UAV, his rig is very nice and clean, and also a daily driver. heavy duty shackles and a add-a leaf. may work
  13. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    my problem with my body lift on a 73 3/4 ton was with the stearing, stearing was never the same it had ruff spots almost felt like humps, high center of gravity, some people said that it makes it weaker, becasue the bolts are longer and can break, im not sure about that one. body lift also open up ur engine under the wheel well, if u dont replace ur hoses and lines it can stretch those, when u move the body up the radiator fan doesnt sit in the center anymore. those are just a few things i noticed.. jsut my opinion on them if you can avaiod them i would.
