4" Suspension with 35 inch tires.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StiffRide81, Oct 4, 2002.
  1. StiffRide81
    StiffRide81 Registered Member
    Aug 24, 2002
    53
    Tinley Park, IL
    4\" Suspension with 35 inch tires.
    /forums/images/graemlins/1zhelp.gifI have 35's on my rig with a four inch suspension lift. My question is... am I going to be breaking all kinds of parts now because of the 35's and if so... what should I get to toughen things up (and dont say a dana 60 for the front an a 14bolt ff for the rear!!)
    /forums/images/graemlins/k5.gifThanks.
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    Re: 4\" Suspension with 35 inch tires.
    well i have the same thing, and all i bust is ujoints, but i have only busted 2 in the past year and 3 months
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Its all in how you drive.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I ran a 4" and 35's for years on my '79 with 1/2 ton gear. I had no problems. I wasn't what you would consider a hard core wheeler, but I did have fun. I currently run 38's on my '74 with a 1/2 ton D44 and 12 bolt (I'll probably get falmed for this combo, but I don't care /forums/images/graemlins/grin.gif). I wheel it fairly hard (meaning technical trails) and I haven't broken anything yet. If you're not a throttle jockey then you should be fine.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Well this has been covered many times before. If you drive easy, you will likely not have too many problems. The 1/2 ton axles are probably the weakest links, especially the rear. Make sure you use good U-joints everywhere and that everything is properly maintained. If it isn't broke, don't worry about it. Just drive reasonably, knowing that there is a potential weakness.
    When you break 10-bolts, the parts to fix them are easy to come by. But if you do break a lot and get tired of it, you can always get a 14BSF 6-lug axle for the back and swap it in without needing a new front axle or new wheels.
  6. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I run 4" lift and 35's. Have had them on for over a year. AT first i busted U-Joints, but it was because my driveshaft angle was correct, i actually screwed up my whole tail shaft on my tcase and the ujoints and dropped my driveshaft on the street due to it. Since I got my angle corrected and went to spicer ujoints... i have had no problems. I think the height/ride are perfect for me. I have a 79, 10 bolt front, 12 bolt rear. And currently I am running stock gears. I have the Goodyear Wrangler MTRs, on Mickey Thompson Alcoa Classics. /forums/images/graemlins/k5.gif
  7. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    sell ya a D60 and 14ff with 4.10s /forums/images/graemlins/smile.gif /forums/images/graemlins/tongue.gif
    Of you can do the chromo parts in teh 1/2 ton stuff but I think by they time you get all those parts you could get a set of 1-ton gear.
  8. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    Been running that way for 5 years (35's, 4", 10b). Only broken U-joints and one shock mount (don't land on big rocks when you're flying /forums/images/graemlins/wink.gif )
    Jon /forums/images/graemlins/burb.gif
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have been running that combo for 2 years and I only broke front axle U joints when I put a front locker and wheeled it hard on rocks, but those joints were old anyway, I will replace them with the best U joints I can find and I don't think I should have any problems.
    Up to 35" should be fine with 1/2 ton, you could get away with 38" if you know how to wheel them beyond that it is easier to go 3/4 or heavier.
    IceMan
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im running 35's on 4" of lift and my rear end broke on me a couple weeks ago, Here is what was left of the carrier. So i picked up a 14SF 6-Lug, Let me tell you this axle is beefy for a 1/2 ton axle. I dont think its gonna break on me.
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's not a 1/2 ton. It's the light duty 3/4 ton.
    IceMan
  12. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I am runnin on 12 bolt & D44 1/2ton equip w/ 6" lift 2" body 38" TSL/SX's Got CV in rear drive line /forums/images/graemlins/grin.gif. So far no problems! /forums/images/graemlins/thumb.gif
    Bill
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Bill, you've been lucky so far! I ran 38s on a beefed D44/12 bolt combo and broke pretty much everything at various times. I gave up after the second ring gear in the 44 and went 1 ton.</font color>
  14. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Someday I'll go 1ton as I can afford to later.
    Bill
