4" Taller
Discussion in '1936-Present Suburban' started by dleroy43, Nov 2, 2002.
  1. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    4\" Taller
    Got the lift on yesterday with minimal fighting. But I can only drive around the block counter clockwise till my arm gets here. any suggestions to get the old one off easly? /forums/images/graemlins/burb.gif
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Re: 4\" Taller
    Start soaking it with liquid wrench now and hit it down, up, and sideways with a BF Hammer. When are you going to send a pic? /forums/images/graemlins/thumb.gif
  3. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    Re: 4\" Taller
    Heat is the best solution. Small propane torch from hardware store works well $9.75
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 4\" Taller
    You should be able to steer fairly well without the raised steering arm, if the drag link is adjusted correctly. Try adjusting the drag link until the steering wheel is centered again (make the drag link longer) and you'll be able to turn the wheels both left and right. /forums/images/graemlins/wink.gif
  5. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    Re: 4\" Taller
    I adjusted the drag link so now I can drive both ways around the block. pics will be up as soon as I get them developed /forums/images/graemlins/cool.gif /forums/images/graemlins/burb.gif
  6. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Re: 4\" Taller
    Just knock the arm down then grab the cone washer thingys then screw them out like a threaded nut. I've just about got this down to an art now. /forums/images/graemlins/grin.gifWith your drag link adjusted just don't go wheeling or do anything that requires any amount of wheel travel up front. the drag link just won't take the angles.(knoledge form experience)
