4 to 6inch lift
Discussion in 'OffRoad Design' started by buddiesel, Nov 19, 2003.
  1. buddiesel
    buddiesel Registered Member
    Nov 6, 2003
    8
    Albany, NY
    My 88 K5 is currently on a 4" lift, springs in the front blocks in back. I want to step it up to 6" any way to reuse some of the parts on my 4" kit to save some money? I am thinking new 6" springs for the front then somehow use my front springs with either blocks or a shackle flip in the back.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Just go with some 6" front springs, 4" shackle flip and 2" blocks with your stock rear springs and call it a day /forums/images/graemlins/thumb.gif
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    If you want a 6" lift you could use the ORD Zero rates in front, shackle flip in the back with Zero rates and a 1"body lift. This would be a total of Six inches of lift. Or you could go with only the 1" body lift and leave the suspension alone. Call ORD and talk to Beck for this week as Stephen is out of town until Monday.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    This comes down to a bunch of questions about how you use your truck and how much more modifying you're willing to do. You really have to be prepared to mess with brakelines, shocks, driveshafts, steering correction, etc all over again. Some of this may have been adequately addressed with your 4" lift but it all needs to be considered. The driveshaft angle is kind of a big one here. With a 6" lift, you'll have a hard time getting away without a CV joint. With the 4", it can be done in some cases.
    Doing the 1" body lift is a good way to pick up some clearance without messing up very much other stuff. I'd say you should strongly consider what a 5" lift will do for you, it's a lot easier and cheaper.
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    I have done just about what Stephen said, I started with a 4" lift and added a 1" body lift and 1" add-a-leaf in the rear to cure saggy butt, with the 5" of lift in the front and the 6" of lift in the rear is sits level and has room for 39.5's /forums/images/graemlins/thumb.gif Well, with a little fender trimming. /forums/images/graemlins/wink.gif
