4" TUff country lift problem
Discussion in 'The Garage' started by Pow06er, Aug 24, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    ok so i get my 4" lift kit with rear blocks for my '88
    and i look at the blocks and notice they are big like about 5" big so i look at the instructions to see the listing of parts and it says
    2-5.5" lift blocks
    so i figure they must be right
    so i install them
    and now i relize after chatting with other people who have k5s and run TC lifts that they are too big and i need a 4" block and that the front should be noticeably higher due to new leafs and they will sag over time to level out
    so now i gotta remove my 5.5" lift blocks and ubolts and try to see if suspensionconnection can overnight some 4" lift blocks and new ubolts
    and then hopefully have them send me a addressed box so i can mail back the 5.5" blocs
    im pissed to say the least
    altho i did drive it and i had some vibes but were changing the ujoints and hopefully the 4" blocks will give me a tad better angles
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    not a bad thing
    Most blazers are higher in the front than the rear. the extra height is to level it out. My skyjacker softride came the same way when I had a 4" I had 4" springs on front and a 5.5" block on the rear. leveled it out nicely.
  3. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    yea but mine wasnt sagging at all stock i think there is an aal back there but dont know for sure the PO said there was one but i dont know
    damnit im lost at wat i should do
  4. Pow06er
    Apr 9, 2005
    188
    ne, ohio
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    whats the problem? do you not want that much lift? i think you should just stick with the 5.5" block for now. if its just a matter of you wanting it to be level, then get a zero-rate in the front, then youll have another inch of lift to even out with the rear aal, and you could move the axle forward if you want.
    thats what i would do.
    i do see ur point tho, contact them and see how they will compensate you for the inconvience.
  6. Stixx
    Stixx Newbie
    Jul 30, 2005
    3
    Altus, Oklahoma
    Leave it alone!
    You will want the extra lift in the rear. I have a tuff country six inch all spring lift on my 90' blazer, and had to add a set of two inch blocks out back to level it up. The rear is about 1/2 inch taller than the front with the top off,but it is dead level with the top on. Good choice of springs. You will love them. I have a total of eight inches in the back and have zero vibes.
  7. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    well i already have a 0rate in the front with my new springs and the rear still sits higher up about 1/2" it doesnt bother me aobut where it sits now but
    one is the front springs are gonna relax a bit and then its gonna look even more lower
    another is the truck never sagged in the rear at stock height
    and lastly i dont want to be this high in the rear im already getting a vib at 0-30
    and when i let off of the gas about about 30 mph i hear a grinding noise we think its the ujoints so we are replacing them
    so im calling TC and telling them i got the wrong blocks
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Personally , I prefer the rear too sit a little higher then the front. I'd just run it as it is till a later date and then go with a shackle flip, or rear springs. (Note; I'm no fan of blocks)
  9. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    when I installed my 5.5 block it through my driveline angles out of wack and had a bad vibe so I used a 4* shim to tilt the pinion down
    it got rid of most of the vibe had one around 5 mph
    but my angle were maxed out
    my only other option was a cv driveline but it would of required a huge freaking shim so I decided screw this and I ditched them for a 4inch shackle flip
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    On most Blazers the rear 5.5" block will make it sit level with 4" front springs as already mentioned. You stated that your Blazer in stock form already sat level, and that you thought there was an AAL installed in the back.......there was no way for the suspension company to know this unless you told them before ordering the kit.
    In any case, call them up and they would probably be willing to exchange the rear blocks.
  11. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    yes its been done im getting a 4" block from suspensionconnection overnighted and im getting a call tag for my 5.5" blocks very good customer service
    Im contemplating making up some 1" flat bar to use as a drop tcase to give me better angles
  12. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    if i do the 4" block thats tapered and then go and do a 1" tcase drop will the taper in the blocks and with the lowered tcase overcorrect and give me too much of an upward angle on the pinion?
