4" vs 6"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big Bad 82 K5, Jan 23, 2002.
  1. Big Bad 82 K5
    Big Bad 82 K5 Newbie
    Nov 30, 2001
    3
    san antonio tex
    4\" vs 6\"
    I was wandering how high i should go with my 82 K5 i want to go with the 6" but some people say it will be to top heavy to go with the 4". I plan to run 35 or 36 inch tires can any one give me some info on that thanks .......Jason
    K5 what real men drive! Just runnin over the competition
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Re: 4\" vs 6\"
    I rubbed with 35s. Started with 4" (ft spring and rear shackle flip) and added 1" zero rates and 1" body lift.
    I like it - doesn't feel tippy. And I still rub :)
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    Re: 4
    Someone in the know once told me, "Go with as little lift as possible for the size of tires that you want to run." I trimmed my fenders and am having no problems clearing 35s with about 2' of lift. The current lift is an add-a-leaf in rear and shackle extention front. This set up sucks as far as ride is concerned but clearance is no problem. I plan to use a custom shackle flip in the rear and remove the add-a-leaf and use 4" springs up front with greasable shackles. I also plan a one inch body lift mostly because I need to change the body mounts really bad and I want to do it all at once. This will total 5" of lift and that will allow considerably larger tires that 35s.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74 K5 Blazer Topless W/ 35 BFG Muds (See profile for pics)
  4. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Re: 4\" vs 6\"
    If you are planning 36" tires, you should go with the 6" lift unless you want to trim your fenders. Unlike many others here, I am not a fan of fender trimming. Before the body lift, my 36" tires rubbed A LOT with the 4" of lift.
    <font color=red>"DON'T TAKE LIFE TOO SERIOUSLY, YOU WON'T GET OUT ALIVE."</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
