4 wheel disc probs....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86jimbo, Mar 17, 2006.
  1. 86jimbo
    86jimbo Registered Member
    Sep 8, 2005
    59
    Arkansas
    I put 4 wheel discs on my blazer when I built the 1 ton. No 1/2 ton brake system would work very good, so I put in hydroboost. It works pretty good, but I notices that the front brakes are wearing and the back is not at all. Can that be that Im still running a stock prop valve? If yes, what should I get to resolve my problem? Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Get an adjustable prop valve so you can control front to back pressure.
  3. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    When I added rear disc brakes to my blazer (dana 70) the breaks worked like crap, so.....I removed the factory porportioning valve and replaced it with a willwood porportioninig valve (to control the rear pressure). Works very good now. Hope this helps.....
    Ryan
