4 wheel drive Broken?
Discussion in 'The Garage' started by unicknn, Jul 19, 2002.
  1. unicknn
    unicknn 1/2 ton status
    Jul 5, 2002
    138
    In San Diego now but Im from Texas
    How do I check id My 4x4 is working? Today I put it in 4 hi and I looked at my wheels and they didnt look like they were working. Whats the best way to check it?
    lmk
    Nick
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Get a buddy to help you. Engage the transfer case and get your buddy to get low and watch your front driveshaft as you drive by slowly. If it's turning then you know your TC is working and barring any massive front diff problem, your 4x4 should work.
    If the front driveshaft isn't turning then you probably have to adjust your transfer case linkage.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Did you get to look at both wheels? Most trucks have an open front end, so only one wheel will turn.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    if the driveshaft is spinning make sure your hubs are fully engaging also at the wheels.if one is not engaged the axle at that side will only spin unless you have posi or a locker.
  5. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    JUST PUT IN 4WHEEL DRIVE LO OR HI DOESNT MATTER OPEN THE DOOR AND JUST LET IT IDLE AND LOOK UNDER THE TRUCK. IS THE DRIVE SHAFT SPINNING?
    SORRY ABOUT THE CAPS WORK SUCKS.
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    If the hubs are locked they will spin the shaft, so that is not the best way to test. Also the the drive shaft may have power but the hub won't engage, so thats not reliable either. Some spippery surface would be a good way to check. Put all 4 tires on it and then hit the gas.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Exactly...find a gravel road, lock in your hubs, put t-case in 4Hi or 4Lo and hit the gas, if your leave a burn-out track on the gravel from your front tires, your 4wd is working.
  8. 89chevy
    89chevy Registered Member
    Apr 23, 2002
    70
    lafayette Cali
    yeah what muddytaz is saying, only instead of checking the ground for burn marks... check for DINGS in your front quarter panel! /forums/images/icons/shocked.gif /forums/images/icons/tongue.gif
