4 wheel drive problems
Discussion in 'The Garage' started by 91 full size jimmy, Jan 19, 2007.
  1. 91 full size jimmy
    91 full size jimmy Registered Member
    Jul 4, 2005
    41
    NH
    I went wheelin last weekend had 4 wheel drive went in a hole herd a noise no more 4 wheel drive. thought it was the hubs checked not them, checked axles not them, puled off front diff cover looked fine, drive shaft has some slop in it. what else can it be?
  2. GruntHunter
    GruntHunter 1/2 ton status
    Apr 28, 2002
    145
    Florida (Space Coast)
    Check your front drive shaft again. I had that happen to me and I had to leave my Blazer stuck overnight and walk 6 miles to get help. It was weird because when I had it on a frame rack the front axle would drop down enough to where the spline caught eonugh to where it appeared OK. When it was sitting on all 4's a friend crawled under and found the shaft slipping on me. The entire spline didn't strip out, only part of it, probably when I was going through a mud hole and it was extended.
    Just a thought.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    X2 MANY TIME I HAVE SEEN THIS.:wink1:
  4. 91 full size jimmy
    Jul 4, 2005
    41
    NH
    well it was the front drive shat the teath were almost gone. thanks for the help
  5. goldwing2000
    goldwing2000 Guest
    That's a Freudian slip if ever I saw one. :D
