4 wheel lo grinding noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, Mar 5, 2001.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    Ok, in all the K5/Jimmys I have owned when I go to put it into 4 wheel lo it will make a grinding noise when the regular trans is in neutral or park. I only got it to work once like that when i was stuck but 4 wheel lo didnt help either. It went in once without grinding but other than that i would turn the truck off and put it into 4 wheel lo and it wouldn't grind. If it helps all the trucks had auto hubs. Does anyone know what causes this and how to avoid it? I would like to know for future references because i will be buying another K5/Jimmy/Suburban or pickup asap.
    JD
    Former owner of an 88 Jimmy and 2 87 K5's
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Try shifting while rolling leaving the tranny engaged. As for why, even though the tranny is in neutral, the internals are still spinning- hence the grinding.
  3. MudRebel350
    May 20, 2000
    324
    N.J.
    Come on, this must have happened to someone before.
    JD
  4. MudRebel350
    May 20, 2000
    324
    N.J.
    Thats what i thought of why it was making that noise but i wasnt sure. Has this happened to you FWP?
    JD
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Exactamundo[​IMG]. There is a good post back aways, when I asked about how the other guys were shifting the t-case. I was of tired of the annoying grind. Do a search- you should find it.
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Can't dilly-dally when shifting, just grab it and throw it back as fast as you can.
    Two lanes wide, twelve yards long, sixty-five tons of American pride....Canyanero!
