4 wheel low problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by H0BBEZ, Oct 4, 2001.
  1. H0BBEZ
    H0BBEZ Registered Member
    Sep 19, 2001
    38
    Frederick, CO
    I'm not sure if maybe this is just a standard occurrence 'caused by high RPM or something, but if I'm in 4 low and in first gear my service engine light will turn on. Then just as soon as I shift to second it turns off again. I haven't tried getting the error code out of it yet. But it's an '87 K5 with the stock OHV Eight-cylinder 350 cid., automatic (TH700-R4) and NP208 transfer case.
    Any thoughts?
    Thanks,
    H0BBEZ
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    TThat sounds fishy to me. Probably some sort of bad switch or something. I have never had good luck with that light. Weird thing is it hasn.t gone on in a long time. It used to go on every once in a while...
    Surfing is Life...
