4 WHEEL STEERING
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BFT OFFROAD, Mar 14, 2002.
  1. BFT OFFROAD
    BFT OFFROAD Registered Member
    Jan 24, 2002
    6
    VIRGINIA
    I WANT TO TAKE A FRONT 10 BOLT AND PUT IT IN THE REAR END OF MY K-5 SO I CAN HAVE 4 WHEEL STEERING. JUST WANT TO KNOW IF ANYONE HAS DONE THIS TO THEIR BLAZER ?
    84 K-5 10"SUSP. 3"BODY 39 " MICKEYS
    GO BIG OR STAY HOME!!
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    well then u will have to have all the componets that are in the front in the rear as well.
  3. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Don't use a ten bolt. My buddy did and couldn't keep the u-joints alive.
  4. BFT OFFROAD
    Jan 24, 2002
    6
    VIRGINIA
    I HAVE A COMPLETE EXTRA 79 CHEVY BLAZER TO TAKE ALL THE PARTS FROM. WHAT KIND OF STEERING?? HYDR.
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Unless you plan on re-tubing the front 10 bolt the differential is offset and won't work with the transfer case mounted as is, ie the driveshaft. Plus, a 10 bolt wouldn't be my first choice for a rear axle.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Although expensive (but cheaper than custom axles, take a rear Dana 60 and a front dana 60 and put the front knuckles on the rear axle (may have to shorten axle tubes) and put under your rig. You can use the front outer shafts, knuckles, rotors, spindels, hubs, calipers, etc., but you will have to have new inner shafts made to compensate for the different pumpkin offset of the rear as opposed to the front. You will also need someway to control the steering (hydraulic, manual over hydraulic, etc.)
