4 Wheelin' Burnout
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jun 6, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    4 Wheelin\' Burnout
    Today, one of my moronic teenage "freinds" suggested that it would look cool to see a burnout in 4WD. I thought this over and although it would be cool to see, wouldn't this reek havoc on the drivetrain? I wasn't going to do it though despite my freinds taunts. Just wondering what damage it would cause. thanks.
    YEEE HAWWW[​IMG]
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 4 Wheelin\' Burnout
    First, if you plan to do this on pavement, you need LOTS of torque to do it. With a stock or mostly stock 350 you're just going to take off, even in low range. I've done some great 4-wheel rooster tails in the dirt but there's just too much traction on pavement.
    Oh yeah, try it too many times and I sure hope you have a very stout drivetrain! [​IMG]
    <font color=blue>http://ThunderTruck.ColoradoK5.com</font color=blue>
  3. Black89k5
    Black89k5 Registered Member
    Mar 12, 2000
    42
    Ha!! Torque!! Not to offend anyone but i had a 327 in my 82 that put out about 550 horses and about 530 ft/lbs of torque (right out of my nova after i wrecked it) locked in my hubs put it in 4Low and stomped on that sonuvab**ch and all mine did was bind up the tansfer case and i lost 2 driveshafts and universals. So i hate to say it but torque aint always gonna do it.
  4. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Try it and you'll be like Mr. Black...Broke. Unless you can find a way to hook to a big a$$ tree or something and ease on the gas maybe then you'd have less of a chance. Motor torque like flooring an auto off the line won't do much but like dumping the clutch or neutral to drive it (I HIGHLY DON'T RECOMMEND!!!) you aren't playing as much with engine torque as you are with all the rotating mass that's trying to slow down. So all in all I'd say don't try it........ if you want to do burn outs get a rental car...
    Wasn't me.............
  5. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I have warn hubs in the front of my truck and would put it in 4lo. Quite a nice show. The truck will do it in 2wd, but it helps to have the tires turned to the right to take a bit of the load off the right rear under torque. The 4lo situation takes the cake tho.
    I will mention that one time I blew a $350 six states CV Shaft into more pieces than dollars I spent on it doing that, so I don't really suggest it on pavement.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would not doit with my rig but i would watch someone else doit[​IMG]!
    If you sdecide to chance it then bring some dish sope with you and soake all four with soap then roll front and back to get a soapy track then nail it!!
    If you do this have a camera taking picks so we can see it!
    Or better yet video it and post the vid on the web for us!![​IMG]
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Tell them a 4 Wheel Drive burnout is done in extremely deep mud. Say "Stand right back there to watch the tires squeal" [​IMG]. Whats all this dragracing stuff in a 4x4 anyway? Tell them to follow you sometime through some real tough stuff. That will "prove" your worthiness.
    Mudzer 1978/91 K5
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I wouldn't try it. Too many possiblities of breakage.
    Now, my friend bought a 2001 Dodge 3/4 Extended Cab long Bed 4x4 with an Auto and a Cummins Turbo Diesel. Man, Will this thing lay two huge strips of rubber!!!!!!!!!!!
    In the parking lot of a local resuraunt, there are two nice strips about 30ft long!!!!!!
    Hearing the diesel and the turbo screamin is also a plus!!!
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
  9. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, I won't be trying this anytime soon, a new drivetrain is not on my starving student budget!
    YEEE HAWWW[​IMG]
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Post deleted by BlazerGuy
  11. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Not worth the cost or replacing most of the driveline just to see a bit of smoke. I do remember an old photo of a Hurst Olds 442 with 2 motors that could light up all four...but that was long ago and I have slept since then...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  12. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    I have done it but only the rear tires, I wouldn't do it again though, if I didnt break anything the last time the next time I probably will.
    check out my new site, thanks Steve!
    http://chaka73.coloradok5.com
  13. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    One of my friends was playing with his dads FS chevy pickup after a new 454 was dropped in it. He put it in 4low and side-stepped the clutch. Those brand new 31's left some pretty cool patches as the truck started to slide sideways before it took off. He didn't get to drive the truck much after that.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  14. rem7600
    rem7600 1/2 ton status
    Apr 16, 2000
    125
    Coeur d\'Alene, Idaho
    Come on GUYZ, I came to this post to
    see pictures! :-)))) I thought, "Man,
    whose the dummy that tried/did this?"
    I especially liked the post that said
    550hp and 530+ torque... I think that
    post says it all. Sorry 89BlackK5 that
    you had to mess up the checkbook to
    find out for us all. I suppose it sounded
    like a good idea at the time. :-) I
    can see me, years earlier, with a few
    brewskies in me, making the same
    attempt after some heavy taunting... I
    once made an attempt to JUMP a snowbank
    with 4 people in my 82K5 Pickemup. Lemme
    give you a little advice... Don't try
    it!
    I'd love to see a pic of the 4wd burnout
    if anyone ever finds one!
    <font color=purple>REM7600 - '89 Jimmy</font color=purple>
  15. Zack
    Zack 1/2 ton status
    Feb 18, 2000
    329
    IL, USA
    Well in alot of magazines that show the S10 V8 Swap they use the picture of a 4wd s10 blazer doing a 4 wheel roast session.. Wow that is cool.. I have done a 4 wheel burnout in my rig but it was on gravel/pavement mix. Still looked cool.. Next time I gotta bring the camera to have proof.
    <font color=red>Zack Carlson</font color=red>
    <font color=yellow>Carlson@thestix.net</font color=yellow>
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That S10 was probably rolled thru a burnout box first to smoke all 4. Hell, with wet tires I can get some smoke with my stock 305 turning 33's! Not that I do this often...[​IMG]
    [​IMG] Semper Maintenance!
  17. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The stock axles under an S-10 would explode in short order from doing 4-wheel burnouts. The wimpy 7.5 inch rear and those front Cavalier half-shafts can't take much abuse. [​IMG]
  18. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Kinda like a proportionately larger K5 Blazer would be with stock 10 bolt front and rear axles, right???
    ken
  19. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I've blown apart a bunch of 12-bolts and pounded the hard-facing off of the side gears in a 10-bolt. So yeah, probably about right.
    That's why I'm running a 14-bolt FF now. [​IMG]
  20. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I've seen a guy here do it in a pickup with a 350 with 44's at least 25 times nothings wrong with his rig.
    Bigger is Better
    Cameron Burnett
    82 Jimmy
