4" with 35's
Discussion in 'The Garage' started by 91k5NC, Feb 6, 2003.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    4\" with 35\'s
    im getting a 4" with 35's and putting them on 15x10 inch rims how bad will my finders rub alredy trimed a little. /forums/images/graemlins/k5.gif
  2. hardcore_rob
    hardcore_rob 1/2 ton status
    Dec 6, 2002
    111
    Colorado Springs, Colorado
    Re: 4\" with 35\'s
    I am running 35/12.5/16.5 on the stock 8 inch and only have a 3 inch lift , seem to have plenty of space, have yet to get it to rub at this point.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    Re: 4\" with 35\'s
    i had the same setup on my jimmy, and i had to trim a tiny bit and then they cleared fine. i say go for it
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Re: 4\" with 35\'s
    It shouldn't rub if you dont take it off road. If you think you're gonna hit anything major, straighten your wheels. That'll take up most of it. /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  5. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Re: 4\" with 35\'s
    I have that same setup. The only time it rubs is when I am off roading. I would say do it. Just trim the fronts back about 1/4 to a 1/2 an inch and you will be fine. This setup is what my freinds call stock. But then I can't afford 20" of lift and 44's. /forums/images/graemlins/eek.gif
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: 4\" with 35\'s
    it all depends on your backspacing /forums/images/graemlins/shocked.gif /forums/images/graemlins/thumb.gif
  7. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    Re: 4\" with 35\'s
    I am running 35" BFG's with 2.5 inch of lift. Trimmed about 1 inch off both front and rear of the front fenders. The only time I rub is full lock full stuff!
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Re: 4\" with 35\'s
    depends on a lot of factors really... but when i had 4"/35s, if my sway bar was disconnected it would rub... and rub pretty hard. If i remember right, i had 1" of body lift as well. Depeneds on how soft ur suspension is, what the real diameter of your tires is etc etc
    j
  9. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Re: 4\" with 35\'s
    I run a 4" lift and 35's, no trimming and havent come close to hitting, (that i know of) but then again, i don't do hardcore stump jumping or anything.
  10. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Re: 4\" with 35\'s
    To Hardcore-I found 16.5 wheels with saftey lips{right term} on them.They are only 6.75 wide,but,are 4000 lb rated trailer wheels.Got mine at yard sale while in Fla couple years ago.I know size cause it's stamped into wheel.Work fine with 12,50 X 38 TSLs.Just a little useless knoledge. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Re: 4\" with 35\'s
    You might want to keep an eye on that if you go wheeling. Several people on here have claimed that untill they actually looked closely.
  12. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    Re: 4\" with 35\'s
    I also have a 4" lift and 35" BFG all terrains. I use the truck for moderate off roading and do not rub at all, so I say go for it. /forums/images/graemlins/k5.gif
  13. blwnbwtie
    blwnbwtie Registered Member
    Jun 4, 2002
    72
    LA California
    Re: 4\" with 35\'s
    I have 4" on 35s i hammered the corner of the fenders in a little and they still rub a bit but nothing too major. Only rubs when im off-roading not driving on the street. I wouldnt worry about it. /forums/images/graemlins/k5.gif
  14. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Re: 4\" with 35\'s
    I have 4" and 33x12.5's and I can make my tires rub under full compression on 15x10 rims. Just depends on how you wheel it.
  15. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    Re: 4\" with 35\'s
    my wheels stick out about 2" in the front so that is what i was worries about.
  16. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    Re: 4\" with 35\'s
    well i am about to go with 38's on my 4" rough country setup, and cut the fenders and add flares /forums/images/graemlins/deal.gif
  17. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Re: 4\" with 35\'s
    Mine rubbed as first, but after a short wheeling sesion The tires took care of most of the loose metal. What ever was left fell to the hammer, and i think it was the quickest, easist, and cleanest trim jobs ever.(same set up btw) /forums/images/graemlins/thumb.gif
  18. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Re: 4\" with 35\'s
    I've got a 4" lift on my 89, although it's maybe closer to 4.5 or so (3" Tuff Country springs, Hill extended shackles, and pinion shims that add maybe 1/8"). ORD 4" shackle flip in the rear and no problem there, however I do rub up front when wheels are turned, my trim has been "relocated" on both sides by the tires. /forums/images/graemlins/smile.gif No cutting yet and I haven't used the swaybar disconnects either until I do.
