4"+ zero rate or 6" spring
Discussion in 'The Garage' started by stockk5, Jun 30, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Hey what would you guys recommend doing? Right now i have 4" rough country springs in the front, i want to get up to a 6" ish lift. I am on a pretty tight budget so i was thinking just put a zero rate up front and i would be close to 6". My question is do most leaf springs run true to their spec height or lil lower/higher?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I didn't measure my truck before/after the springs, so I can't help 'ya there. You may need longer u-bolts if you use a zero rate - more $$$.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Can't really answer your question about the springs being true, it depends on the spring, but I use the zero rates from ORD and they are great.
  4. 87blues
    87blues Registered Member
    Jun 2, 2005
    24
    Virginia
    New to the 4x4's, what is zero rate, what do they do? I put a 4" Rough country lift on my Jimmy and love the height, just got some vibration after some other stuff.
  5. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    A zero rate is an add-a-leaf that does not make the spring stiffer. It bolts to the spring pack w/ the center pin and is safe up front. Gives 1" of lift. Had one on my Chevy w/ 4" springs and just swapped them out for 6" tuff country springs.
  6. 87blues
    Jun 2, 2005
    24
    Virginia
    Okay, thank you for the info. I'm learning as I go, but loving it.
  7. cbbr
    Jul 17, 2004
    14,681
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd save up (Yeah, like that is possible when you're on a tight bugjet) and get some quality springs. In all honesty, Tuff County and BDS arn't all that expencive. Buy a few parts at a time and drive it like it is till you have aquired everything, then have a wrenching party. Personally I think Rough Country rides like a lumber wagon.
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    question: why do you want 6" of lift? makes it easier to answer your question...
    j
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    from my experience, BDS tends to run a lil on the big size, 6" lift is around 7" and 8" lift is around 9". maybe 4" BDS would be 5"? i dunno zero-rates are nice cuz u can move the axle, id prolly get thosea nd then if u want more height, get new springs.
    BDS rides real good, before i got my 8" bds lift i had 2" trailmaster from previous owner, and it rides better now than with that tiny lift. I really recommend BDS.
    87blues, where in VA are u located?
  11. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    hey i wanted a 6" lift because i plan on running 40" tires and trimming my fenders.
  12. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    if you are willing to trim, I say stick with 4" springs and add the zero rates. I run 39.5s on 5" of lift np... will probably go to 42s when my 39.5s are bald.
    j
