40 / 17/ 16.5 GROUNG HAWGS
Discussion in 'The Garage' started by k5elky, Oct 8, 2003.
  1. k5elky
    k5elky Registered Member
    Sep 27, 2003
    11
    Los Angeles, Ca
    I RECENTLY INSTALLED SOME USED 40 INCH GROUND HAWGS AND THE RIDE HAS BEEN HORRIBLE SINCE THEN. IT FEELS LIKE THE TRUCK IS FALLING APART. IT BOUNCES SHAKES AND IT FEELS LIKE I HAVE NO CONTROL. THEY ARE NOT BALANCED.. CAN THAT BE THE PROBLEM?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    YES, THAT IS LIKELY THE PROBLEM.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes that IS most likely the problem /forums/images/graemlins/eek.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you beat me by seconds /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. k5elky
    Sep 27, 2003
    11
    Los Angeles, Ca
    thanks guys! I did want to have them balance but all shops around here say the tires are too big for their equipment. Anyone know where I can get them balanced?
  6. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    That all depends on where you are...
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  7. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Toss about half a dozen golf balls in em. If it still shakes add some more.
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Yep, golf balls work, but for that big of a tire I'd go with more like 8 or 9 to start. You can also put about 1/4 lb of BBs in each one of them.
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    its called Bias ply.you can balance all you want and it will still ride like crap................................
  10. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    how in the hell do golf balls or bbs make it balance
  11. burbBoy
    Feb 4, 2002
    358
    WI
    A roating tire will automatically balance itself if there a is a movable mass like golf balls or bbs to do it. As long as there is enough movable mass the tire will become perfectly balanced.
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Someone once explained the physics to me, but it's much easier to just say that it works. It works. /forums/images/graemlins/thumb.gif
  13. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    seen a Article in one of the magazines about Balancing large tires like yours.The problem with bias ply tires is that they are not perfectly round like a radial tire.what they do is spin the tire while it is on the truck.(jacked up)as the tire spins a cutter removes the high spots of rubber and they end up Round,from what the article said the outcome is a great improvment.....
  14. k5elky
    Sep 27, 2003
    11
    Los Angeles, Ca
    I'm in L.A, Ca. I called 4wheel parts and they charge $25 per tire. Should I go ahead and get it done there, or am I better off putting gold balls in there?
  15. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    What type of balancing????
  16. k5elky
    Sep 27, 2003
    11
    Los Angeles, Ca
    I dunno. I explained what problems I've been having and he said that rotate and balance is what I need. is there dif types?
  17. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    dynamic, static, road force analysis... yes, lots of different kinds of balancing. I would try the golf balls first, weights tend to fall off when you go offroad, so you'd just have to get it redone. The golf balls are like active balancing, they'll constantly readjust themselves to keep the tire balanced.
  18. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep,spin balance,static balance,sand balance,Shaving like I explained in the one post,also someone told me if you find a shop that does large truck tires they add rubber patch weights on the inside of the tires.no visable weights,Expensive though
  19. k5elky
    Sep 27, 2003
    11
    Los Angeles, Ca
    k, i'll try the golfballs and see how that works. Would 8 in each tire do the job? would it be a bad idea to put a bunch...maybe 12, 13 or 14? /forums/images/graemlins/ears.gif thanks for all the help guys
  20. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    did you try fooling with the air pressure.what did you inflate them to?(pressure)
