40 spline worth it ???
Discussion in 'OffRoad Design' started by redneckryder18, Nov 8, 2005.
  1. redneckryder18
    redneckryder18 Newbie
    Oct 1, 2005
    ohio
    I am getting ready to but a set of superior axles and ctm u joints for my rig and was wondering if it would be worth it to step up to 40 spline inners? My rig has a 79 ford high pinion Dana 60 under it. I already bought new bearings and brakes for the front end so i want to stick with 35 spline outters for now but i am going to buy a new ARB. I want to know if it would be wise to buy the 40 spline ARB ( extra 400$) and forty spline inners that way if i do start breaking stub axles i will just have to buy the forty spline outters, hubs, spindles etc but not a new lockers or inners? is there any extra work if i buy 40 spline inners and 35 outters? do i have to change anything besides the locker for the new inners? Will this make the outters weaker than normal?My rig is a single seater with a real healthy big block chevy, 250 shot of NOS, Turbo 400, ORD doubler and 49" Iroks. I also really like the skinny pedal. :D
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i havent heard of 1 person to brake superior 35 spline d60 outers or inners w/ ctm joints. i wouldnt bother. besides its lifetime warranty. save your money and put it into something else.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    btw, they make 40 spline outers? or are you thinking 30 stock /35 upgrade?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I had the chance to do whatever I wanted with this last axle build on wally and went with 35 spline superiors. You have to change a LOT of parts to go to 40 spline and I think the ears on the axle are still going to be the problem, even in the 4340 material. I think you'd have the same ear problems with the 40's as you would with 35's.
    I've done things with the chromo fronts that I probably wouldn't get away with on spicers and I can guarantee that if I hadn't broken spicer stubs by now the joints would be rattling in the ears and the superiors are just fine.
