400 and 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by highlow, Sep 16, 2006.
  1. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    I have 74 with a turbo 350 and a 203 t-case, I have a 400 and 205 to swap in and I need to know if it will be a direct swap or if there are any major hiccups I am going to run into when I do this. I know drivelines are gonna be an issue, but curious about the rest. Thanks
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Since you have a 400/205 assembly this should be an easy, direct swap. You will need a t-case shifter if you don't already have one for a 205. Your crossmember will move back 3.5"~4" but it will work on the new combo. Other than that driveshafts/yoke size/u-joints should be the only catch.
  3. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    You will need a wide open throttle kickdown switch for the t400 trans. There is a bracket attached under the dash that has a switch mounted to the gas petal. A wire from the fuse block (ign hot) goes to this switch and the other wire attaches to the side of the trannsmission. You will also need a fill tube for the th400 and that's about it.
  4. highlow
    Oct 8, 2002
    124
    I appreciate the info guys. This will definetely help!
  5. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    all above and small mod to vac modulator line. as 400 is in diffrent position.
