400 chevy heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevysrule, Dec 18, 2001.
  1. chevysrule
    chevysrule Registered Member
    Dec 16, 2001
    39
    Utah
    Did the stock 400 chevy heads come with 76cc combustion chambers or just 64cc? Does a bigger combustion chamber make more or less power. I know that it will lower compression ratios, but you can fit more air and fuel cant you?
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I beleive a smaller chamber will produce a higher compression. Seems I have heard of people useing 305 heads on 350s to up the compression. Don't have an answer for you on the first question.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Stock 400 heads have 76cc chambers and average flow characteristics. The more compression you can run without detonation problems and having to run high octane gas, the more power you will produce. Remember that with the same type pistons a 350 with 76cc chambers will have a lower compression ratio than a 400 with the same heads. The more volume a cylinder has the higher the compression ratio will be with the same heads.
    '85 K5 : Run it til it breaks, then fix it and go again!
