400 chevy swap
Discussion in 'The Garage' started by chvymudin3388, Jan 13, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    is a chevy 400 a small block or a big block not to sure if it is a small block can i swap it with my 350 and are all the componets the same like intake and manifold and all
  2. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    reply
    it is a small block
    but i am not sure about the components swapping
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    This weekend I am replacing a 350 with a 400. The flexplate on the 400 is different. IIRC the 350 and 400, externally, are the same. I don't know if the intakes are interchangable, but if you are swapping one for the other there is no problem as long as you have the 400 flexplate.
  4. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Yup, the only other thing is the dampener. I think that they are different also. Intakes are interchangeable as are all accesories.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    the flexplate/flywheel and the front dampener are the only things on the outside of the motor that are different. All other external stuff will swap over from 350 and 400. Internal stuff on the otherhand is different.
  6. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    most likly not but make sure its not a 402 bbc. some people might get them mixed up. thay look like a big block as thay are. just 402 cid. if the exaust ports are sistered in the heads in the middle 2 then small block. if all 4 seperate then big block. but likly not.
    and as listed before dampener and flex/flywheel diffrent on 400 sbc.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    When the 69-72 trucks got a '400' it was actually a 402ci bbc (396ci + 0.030" factory overbore).
    A couple other snags you might run into for 350 vs. 400 sbc is the heads. 86+ sbc heads & intake have a different angle on the center intake bolts. 400sbc heads have steam holes - essential cooling feature for the siamese-bore 400 block. (Other sbc heads can be drilled, but cracking afterwards can be problem with some of the lighter castings.)
  8. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    400 is externally balanced. you will need flexplate, balancer. Intake from the 350 will swap over. same with brackets, pulleys etc.
    have fun :laugh:
  9. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    the 400 im lookin at is in a 79 chevy truck so does ne body if its the 402 bbc or 400 sbc?
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
  11. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    as I understand it, the 305, 350, 400 are all based on the same block, and the major difference is in the stroke.
  12. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    The 400 block is very different from the others. It has siamesed cylinders along with a different cooling design.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    not true, the 400 SBC was introduced in 1970. i have seen several "400" fender emblems, open the hood, find a 400 small block.
  14. u2slow
    May 9, 2001
    2,217
    BC Canada
  15. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    what are "siamesed cylinders"?
  16. u2slow
    May 9, 2001
    2,217
    BC Canada
    The block is cast without cooling passages between the cylinders - to ensure enough cylinder wall thickness with the 4-1/8" bores.
  17. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    My 350 to 400 swap ended up being a 305 to 400 swap. The starters are different.
