400 crank into 350
Discussion in '1992-Present Chevy & GMC models' started by Mreetz, Feb 28, 2002.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Does this create a 383? Any suggestions for building a new engine for my '84 is greatly appreciated. I have a 400 block that I've started buying parts for, slowly........
    thanks!!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    From what I hear you need a special crank that is ground down.. (where I dont know...) next summer I am going to make my 350 into a 383 stroker.. a buddy of mine just put a 383 stroker into his 78 vette @ roughly 475hp. He says the gas mileage sucks though.. like really bad.... so this will be a big concern for me......
    guess you need to ask yourself is this a daily driver or are you going to drive far? I plan on driving from NJ to virginia, NJ to upstate NY so I want ok highway mileage.... at least 10-12mpg.....
    my $.02
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    a 400 crank in a 350 with a overbore of .030 will make it a 383. Your other option is putting the 350 crank into the 400 and making a 377, which is a high reving motor. With a truck you wanna make low RPM power, unless you do more mud and sand where you want mid to high, if you build a top end power motor it will be of no use when you're crawling rocks at a couple feet a second.LOL
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds like your buddy has way more cam than what you'll need in a truck. That is probably the main culprit in his mileage woes. I've got a TPI 383 in my '75 K5 that gets about 13.5 MPG on the highway. That's with 4.10 gears, 35 inch BFG Muds and a Turbo 400, so no overdrive. /forums/images/icons/cool.gif
