400 engine with small valves
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Mar 31, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    My engine spun a few berrings and I am rebuilding it. I just measured the intake valve and it is about 1.75 inches? Is this right? I would have thought that it would have come with large valves. What is the exact measurment of the valves? Is there a place on the net that I could look up the casting nmbers to find the combustion chamber volume?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    All small block 400 engines were 2 barrel engines and 2 barrel engines come with 1.72" intake valves in them. The casting number you have i'll bet is "882" being the last three numbers which is a 76 cc head.
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    You can go to mortec.com and look up the casting numbers.
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    My 400 has a 4 barrel on it. Do you think someone changed it over? It looks like it came that way. I'll check what casting numbers I have when I get home.
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have a 1979 KZ with a 400SB and it has an original 4 barrel on it also. We bought the blazer new in 1979 so I know mine has not been changed. I took it over to a friend last night to help me with a rough idle problem and he too was amazed to see a four barrel and not the old chevy 4-2 setup
  6. rx7xj
    rx7xj Registered Member
    Mar 17, 2002
    36
    East TN
    My 77 has the factory 4 bbl carb
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I also would bet the farm (if it is the original engine) that they are 882's which are a decent casting for smog heads.
    The 400's don't spin really high from the factory, and the smaller valves are conducive to good, low torque.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Chevrolet NEVER put a 4 bbl on a 400 small block nor did they ever put a 2 bbl on a big block. This is also how you tell a 400 small block from a 400 big block in the parts store. If you have a 400 small block with a 4 bbl then someone has changed it somewhere along the line.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I have a 400 small block, all factory original with a factory equiped 4bbl. It is true that most 400's came out of the factory with 2bbl's, but the 4bbl was a option in the mid-late 70's. Remember the mid-late 70's there was a gas shortage, so not meny new truck buyers ordered the 4bbl's. I bought my blazer from the original owner, and got the option sheet as part of the paper work. It's clearly marked as a option from GM.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I don't believe that you have a factory 4 bbl 400 small block. I have checked with GM back in detroit and they said they were never made not even as an option. I also know several people who worked at the GM plant here in Fremont when they were building trucks at that plant and they have even said that GM never installed a 4 bbl on a 400 small block. Now if someone were to show me guaranteed documented proof that GM is wrong I would like to see it.
  11. bigmack
    Jan 3, 2002
    478
    Tennessee
    I was looking thru some of my dad's old repair manuals from the '70's and in there they do show a few 400's with factory 4 barrell carb's.
  12. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I live in Detroit. I work in the auto industry. I also have a '79 blazer with a 400 and a 4 bbl. Bought it from the original owner. This thing has never been touched. I would like to see some documentation that says GM never put a 4 barrel on a 400 from this vintage. Anything is possible with the auto industry. By the way, my blazer has a factory air cleaner housing from a 4 bbl.. If someone retro-fitted the 4 barrel do you really think they would buy a factory air cleaner too? I also have a '79 suburban that had a 400 with a 4 bbl. Come to think of it, every 400 I have seen that hasn't been touched had a 4bbl. Never is a pretty strong statement.
  13. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    <a target="_blank" href=http://12.232.225.208/cars/brochures/1977blazer/page8.jpg>sales brousure for 1977</a>
    As you can see in the engine specs a 400 had a 4 barrel carb.
    The 305's came with a 2 barrel carb.
  14. J.R.
    J.R. Guest
    i must agree, i had a factory 400 with a 4brl carb. and by factory i mean it was sold new from the dealer, brand new truck with a 400 small block and a 4brl carb.
  15. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Man, don't EVER say Never when you're talking about GM. They did some strange stuff from time to time and the 4-bbl on the small block 400 thing is DEFINITELY true. I have seen the original 400 in a Firebird with the original 4-bbl. I never knew they come with a 2-bbl, because every one I've ever seen had a 4-bbl. Another example: The parts stores and some people say there was never a 305 with a 4-bbl, but that's true, too because I've seen several of them.
    Will
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ok guys, I sure did stick my foot in my mouth this time. With an overwelming response to my NEVER I must be mistaken or rather mislead sometime in the past. SORRY, I should have listened to my boss a little better when he told me to NEVER say NEVER, he says I should say I never SEEN one before. LOL. Oh well, sometimes we just have to insert foot in mouth and chew a little. LMAO.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No 305 4bbl? Who said something like that? 1/2 ton pickups weren't even available with anything besides that or a Diesel from 81-85 before. I know it sounds strange, but in 1984, when my truck was new, it was a 4 bbl 305 or a Diesel, one or the other, no 350s.
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just spoke with the original owner, and yes, this 400 small block did indead come with a 4bbl strait from the factory.
  19. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Yup, never say never.
    I think there were lots of passenger 400ci's in the early 70's especially that came with 4bbl carb...
    The 305 in my 2wd has a Quadrajet on it
    I also have a 350 from 79 that had 1.72" intakes on it, and also a Quadrajet, rather an unlikely combination, but they did it. The casting# on those heads is 462624 and this head should be avoided at all costs. If you thought the 333882 was a low perf. head, well the 624's are a thinner casting yet /forums/images/icons/frown.gif
  20. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My 85 Jimmy came factory with a 305 4 barrel.
