400 Flexplate? Same as other SBC's?
Discussion in 'The Garage' started by Corey 78K5, Aug 7, 2004.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    400 Flexplate? Same as other SBC\'s?
    Is the flex plate on a 400 the same as other small blocks with the two piece rear main seal crank? If not what is the diffrence and would they interchange with out problems?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 400 Flexplate? Same as other SBC\'s?
    NO!!!
    They absolutely will not interchange. A 400 is an externally balanced engine, the other small blocks are not.
  3. Corey 78K5
    13,055
    Humboldt County, CA
    Thats what I thought, thanks.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the only other motor a 400 flywheel will fit on is the 383 stroker because it uses the 400 crank
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is not entirely true because a 400 crank will not fit in a 350 block without turning the mains down.
    That said, if you're building an aftermarket motor, it should be internally balanced IMO anyway.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've used them on 454's also. Some people say that should not be done but I have never heard a reason why and I've done it for years. In fact the 454 in my Blazer now has a Flywheel off my old 400 that I blew up.
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The reason why is the external weight of the 400 and the 454 are different. /forums/images/graemlins/thumb.gif
