400 Motor Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SummitXMK, Dec 17, 2001.
  1. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    Will there be any differences in a motor from a 81 k30 and my 78 Blazer? They are both 400 sbc motors.
    78 K5 Cheyenne 400 th350 203 stock nuthin' special (YET)
  2. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    If you´re absolutley sure they´re both Chevy 400 smallblocks then there will no difference. FYI, the 400 in that K30 is a swap-in. GM didn´t make the sbc400 in 81.
    Andreas
    406cui of pure sh*t[​IMG]
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    a k30 should have a 454 BB, i think
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    K30's can have either SBC or BBC's in 350 or 454 cubic inches. Don't think 400's available in 81.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    there is a possibility that the older 400 has the 2 bolt main bearings. which seems to be much more desirable.
    Tork DSR
    "look ma, i can make the dog pee white...."
    aol screen name TorkDSR
    <a target="_blank" href=http://www.torkpig.homestead.com>http://www.torkpig.homestead.com</a>
  6. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    If my memory is correct all small block 400's are 2 bolt mains!
  7. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    Actually a few of them were four bolt mains. I have on sitting in my shop, but i am not going to use it. The four bolt main 400's are actually weaker than the two bolts.
    eric
    Don't get me started, you know how i get.
    82k5, 14bff, d44, sm465, np205, 300hp350, rust
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Some 400 WERE 4-bolt mains, but they are considered weaker due to the amount of material removed to make room for the four-bolt cap. The web is weaker.
    2-bolts are better for 400's.
    -- Mike
    <font color=blue> Married to a woman who understands the need for <font color=orange>Hugger Orange. [​IMG] <font color=blue>
  9. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    70 through 72 400 small blocks were all 4 bolt main motors. There is no discernable difference in bottom end strength between the two. I have seen over 700 HP on nitrous out of both blocks with no main cap failure. The factory crank is the weak link but only if you are talking over 500 HP. A stock 400 bottom end built correctly to produce low end torque will not have any failures due to weakness. My $.02.
    '85 K5 : Run it til it breaks, then fix it and go again!
  10. mudddog91
    Dec 28, 2000
    471
    north carolina
    I got into my trusty chevy engine book and I was thinking of the 327.Sorry for the confusion.
  11. SummitXMK
    Jun 6, 2001
    141
    Idaho
    Thanks alot guys that was way more than I needed. That was great!!!!
  12. ricka
    ricka Registered Member
    Nov 24, 2001
    40
    Beaverton, Oregon
    But most of the four bolt mains did have steel cranks, which are desirable.
    Also, 400ci's weren't available stock in 1981. I think it was 1974-1979
    or some range of five years.
    Rick Anderson (rick.d.anderson@tektronix.com)
    Tektronix, Inc. Beaverton, OR 503-627-2630
  13. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    If you are referring to forged steel cranks, Chevrolet never made a forged steel crank for the 400. They were all cast nodular iron. The 400 small block production run was from '70 through '79.
