400 sb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Blazin, Apr 10, 2001.
  1. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    I currently have a 400 sb in my 1985 Burb 4X4. Got an edelbrock hi-rise / Carter 600 cfm on it, double hump heads...etc.
    Going to rebuild it... thinking about going with fuel injection. Let's hear some pro/cons. Thinking about VORTECH heads, but the double humps were suppose to be the best of the best. If I go VORTECH heads/intake, heads will be for the 350 cu. in......valve clearance problems?..... pros/cons ? What about the harness/ECM unit.....pricey? Difficult to convert?
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  2. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    If u go EFI, it will require custom programming of the ECM, so you'd need an aftermarket one or a reprogrammed OEM one. I wouldn't run the vortec heads on a *hot* 400, but a nice low-end torque engine might like them. Aluminum SBC heads are around $850 now, I'd run a set of those instead.
    Squash
    <A target="_blank" HREF=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</A>
