400 sbc, 6.2, front shaft
Discussion in 'Engine | Tranny | T-case' started by 77fixer, Apr 1, 2007.
  1. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    400 SBC Has been previously rebuilt .040 over. Ran good before I pulled it, other than smoking on startup. I pulled the heads for a valve job and never got around to it. It will come with a different set of heads 33417369, because I think I got rid of the originals. It could be put back together and run as is (maybe throw in new valve seals). $150 obo
    6.2 diesel, bad heads. $100 The heads were pulled at a shop and the previous owner decided against repairs. I think everything is there (pump, injectors, glowplugs, etc)
    Front CV driveshaft, 1310, 26.75"-29.75" $40
  2. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
    shipping on the 400 to 77840. it runs good? carbed? what year?
  3. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    It is disassembled to the short block and heads are included. No intake. Yes, it ran good before I pulled it, other than light smoke on startup. It needed a valve job, but the heads that are with it are in decent shape. It came out of a 77. It is a 2 bolt block.
