400 SBC block,crank,rods,heads UPDATE
Discussion in 'Engine | Tranny | T-case' started by J.R., Nov 17, 2006.
  1. J.R.
    J.R. Guest
    virgin block 2bolt mains. block, crank, rods, heads,damper and flexplate all go.. was a running motor when pulled, i tore it down for inspection.. asking $375 thanks
    for thanksgiving im going to be in the KC Kansas area and would be more then happy to bring this stuff along and meet somewhere!!
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    thats a good deal. if you were closer Id snatch it up just to have an extra.
  3. J.R.
    J.R. Guest
    ttt
  4. mudman20
    mudman20 1/2 ton status
    Oct 18, 2006
    126
    minnesota
    motor
    can i get some casting numbers?
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have one ready to go, here in sac CA
    check my for sale post
  6. J.R.
    J.R. Guest
    sure, i will grab them next trip to the shop. should be there tomorrow (tuesday)
  7. J.R.
    J.R. Guest
    the head numbers are 488642.. wasnt able to check block numbers.. i can get the block numbers and will measure the cylinder bore,main bearing bore, rod and mains on the crank over the weekend. i know the block isnt a 509 block..
    thanks, oh and i can deliver these parts to des moine iowa, omaha, ne., and st.paul, mn areas...
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you look on the side of the block, I think the passenger side, you will have the last three digits of the block casting, in my case 509:D
    But you can also get the complete number on the back under the belhousing.
