400 SBC heat problem?
Discussion in 'The Garage' started by Disciples Performance, Aug 8, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys
    now i know the 400 sbc has a problem with overheating quite easily. Now im gonna throw a new high flow water pump into it, right away here and a thermostat. Now should that take the problem away for the most part? cause i cant see how other then those 2 ways it would overheat:confused: any other ideas?
    thanks
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Is your motor built?
    I've got a 400 in my stock 1970 impala. Never had a heating problem. Needle sticks right at 190, even sitting in traffic on woodward for 3 hours during dream cruise. Only time I've heard of heating problems is when people bore 'em out more put power-adders on.
    That said, I can't see a high-flow water pump hurting. Do you have a heating problem currently, or just trying to prevent one?
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Did you just build the motor? Are the heads drilled for steam holes? If not, that's your problem right there, or maybe you used a non 400 head gasket.
    What condition is the radiator in?
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Do you have a stock clutch fan or an electric. If you're concerned, get an aluminum radiator with dual electric fans:D
