400 small block question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TorkDSR, Sep 17, 2001.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    I have a 400 small block and a th350. there is no transmission cooler lines to the radiator, nor is there a spot for them. i thought hmmm maybe it's a manual trans radiator, so i went to work (national auto) and was fidgeting on the comp for a while and it seems as though there were no trans coolers built into the radiator for a 400 sm block. is this true? not does it make sense, but is it TRUE??
    Tork DSR
    I just got a winch, it takes the fun out of things.
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Not true, my factory 79 400sb radiator has the cooling lines.
    Might be a manual radiator, as you suspect. If so, just put an aftermarket cooler on it.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    My 78 400ci th350 has the trans cooler lines as well, perhaps you setup was swapped in by a previous owner?
    What, Me Worry?
  4. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    I think you're better off putting an aftermarket cooler on there anyway.. I have a 77 400/th350 and it has a cooler mounted on the front of the radiator.. I dont recall if it has the cooler lines built into the radiator or not but if I have to replace it i'll be sure to get one for a manual trans since I do have the cooler already..
    mike
  5. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    my 78 400ci has the cooler in front of the radiator for trans. (automatic)
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
  6. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    You want a radiator with the cooler setup if you have an auto. Also run a aftermarket cooler after the one in the radiator for best results. If you ever have a tranny fail flush the lines and rad and any other cooler.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  7. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Run the aux tranny cooler to run before it goes to the radiator, unless it has a built in thermostat. If the return is too cool then it can do just as much harm to the internals as running too hot. Optimum temp for tranny fluid is 180F........ If you put it after the radiator cooler than it may run considerably less.
    Love, Peace, and Hair Grease...........
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm no expert, but I have heard from numerous tranny guys that at least the OD's can never run too cool. Not sure on the 350's though... what kind of damage ? Got some details On this? I'm curious.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  9. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Wrong....my 76 has the original 400 SB and has lines going to the radiator. GM did offer a add-on cooler...missed the winning bid on ebay...Grrrr. It looks just like the optional oil cooler for that year...in fact if you look at the top of your core supports leading edge you will see 2 indentions on both sides where the holes are to be drilled to mount the coolers...just my 2 cents and odd GM memorabilia.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  10. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    He does already have the auxiliary cooler, we were just wondering, because at work when we look up a radiator for a 79 w/ 400 it doesnt ask if it has an auto trans. every other year/motor it asks this. we think it may just be a computer glitch.
    also, we do know that his 400 was swapped in, in the truck vin it calls for a 350.
    --matt
    <font color=blue>86, 350 crate, 33's.</font color=blue>
    <font color=red>Lop Sop Doi Off-Roader</font color=red>
  11. BurbinOR
    5,829
    Oregon
    Have him call Radiator.com - that's where I got mine with the correct part number. Direct bolt-in for my factory 400 motor truck.
  12. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Maybe it didn't ask because the 400 wasn't ever offered with a manual tranny?
    Rene
  13. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    Most likely they only have one listing because you can plug off the trans cooler holes if your running a manuel. They will usually do this if they are identical except for cooler option.
    73 Vega 350SB TH350
