400 Small block
Discussion in 'The Garage' started by Z3PR, Apr 5, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I have a 76 k/5 Blazer. It's got a 400 small block. I'd like opions. I plan to stay small block, but is a 400 better then a 350 for off roading ??? This engine runs fine, no need to replace yet. Just thinking about future possibiltys. I do plan on installinng a COMP CAMS "EXTREAM 4X4" cam. probley the one with 262 duration. A HOLLEY dualplain highrise (tall) intake manifold, and a set of HOOKER headers. Yes, all the crome crap is a must aswell. Probley a gear drive to replace the timing chain, love that sound. This truck had a valve job about 4000 miles ago. I might get a set of COMP CAMS "HIGH TEC" rollor rockers. Oh'well, just thought I'd ask everyone's opion.
  2. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    Ummmmm... Don't take my word for it, but I think a 400 is a big block...
    and I'd take a 400 or 454 over a 350 without thinking twice... of course gas is better for the 350, and you don't get stupid comments from stupid freaking idiots at Autozone (whoops, almost went rant on yo arse)... but you get more power from a 400...
  3. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    The 400 isn't necessarily any better for offroading than a 350, it just might have more power depending on the build of it. Your setup sounds alright, but I definitely wouldn't use the high-rise intake for an offroad truck unless you only play in the mud, because it favors high RPM horsepower rather than low end torque. This is just my opinion.
    Will
  4. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    Capman2k, he may very well have a small block 400. They were fairly common in the 70s in many applications including cars, such as the Firebirds like in Smokey and the Bandit.
    Will
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    ok, the CHEVY 400 is a smallblack, its the biggest SB you could get from chevy. Its also a little bit dofferent from the rest of the Chevy sb's because of a slightly different block design (as far as collong passages and stuff goes) On the outside the look the same. (basically) these could be had in both cars and trucks in the 70's.
    The 400's in pontiacs (ie Smokey and the bandit) were totally different engines, not really a small or big block, sort of a mid-block, ALL of the pontiac v-8's used this midsized block. (from the little pontiac 280 whatever ci to the mighty 455ci)
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The 400 is a small block. Lot of people get confuced becouse the smallest big block is a 396. Chevrolet did make a 402 big block, basicly a 396 bored .30 from the factory. But what I have is a 400 cid small block. I've built alot of hot rods, but never had the goal of low end tork. The hot rods was always for higher rpm, and midrange to top end horsepower. I've been told when I rebuild, to use a 5.7 rod ( stock 400 cid small block chevy uses a 6.0 rod ) and bore it .30 over will give me a cid of 406. I don't know if that's true, but that's what a friend told me. With a flat top piston (9.5 to 1) it's suposta be a real torky motor.(9.5 to 1 so ya can run pump gas) And ofcorse advance the cam for lower end tork.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What would you recomend for a intake manifold ??? I want to go square bore instead of spread bore. I am going to try the HOLLEY TRUCK ADVENGER carb. It's been redesigned for off road use. I do like to go mudding, but also will be going on old trails. I don't plan on much rock crawling, very lightly if any. I live in the Black Hills of western South Dakota. I'm really intreated in wheelinng the old trails to find the old goast towns from the gold rush days. That sounds like alot of fun to me. More mud then rocks on the old miner roads.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's the original motor for the 1976 chevrolet K/5 Blazer.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    400 SB's came w/ 5.56" rods. They are good for a low rpm truck motor but do put more side loads on the cylinder wall. 5.7" Rods are stock on 350's and are easy and cheep to put in...but it is harder to find pistons. A high-rise DUAL-PLANE would be a good choice (longer runners make more torque and I don't think hood clearance would be a issue). If you want good low end torque I would go at least one step smaller on the cam! I think you would be more happy w/ the 250 or 256 if low end torque is what you are after. Also look into Vortec heads if you are going to replace the intake anyway.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just figured out how to add a link so everyone can see my Blazer. It's still bone stock. I just got it a couple off weeks ago. Please tell me what you think.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Will the Vortec head's bolt up, or is there modifacations required ???? Knew the 400 sbc used a different rod lenght then the rest of the sbc's, thought it was 6.0, thank you for correcting me, I'll remember 5.56. I've never had a 400 sbc on the stand. How hard is it to get pistons using the 5.7 rods ??? I usely deal with JEG'S.
  12. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    No replacement for displacement. 400's rock. /forums/images/icons/laugh.gif
  13. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Cheverolet made the 400 small bolock. Pontiac made the 400 big block.
  14. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Also... I tend to favor a 383 Stroker, which is sort of a cross between the 400 and the 350. The 383 uses a 400 crank in a 350 (some machining is needed), along with 5.7 rods (I think), and is bored .030 over. The longer stroke and .030 give you the 383ci and one low-end torque monster. Talk to any machine shop and they'll tell you all about it.
  15. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    lots of misinformation here.
    400 is a SBC. It comes with 5.565" rods from the factroy that give it a poor ratio for hi RPM's.
    The 402/396 are both big blocks. You can tell by the HUGE heads when compared to a SBC.
    The ponitac's are a whole different breed, as is the rest of the BOP line. a 455 would be the way to go if you wanted poncho power, but that is a different thread.
    The Vortec heads will not work (as intended) because of the lack of steam holes in the heads. This is the weak link in the 400. These steam holes is where 98% of blown head gaskets start (like mine is right now). The 400 you have is problably a 2 bolt main with 882 "smog" heads (if all is factory).
    If the engine is storng, no reason to screw with the bubmpstick. Headers work WONDERS for the SBC, as the factory manifolds are very restrictive, especially those in the "smog years". Good headers, an Air Gap Performer manifold and a well tuned carb and ignition will be fine.
    I hope this clears the air...
  16. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    You are in to the same action as me... I would go with the edelbrock performer series intakes, esspecially if you are going with a bigger cam. Edelbrock's Power Packages are no joke and all the components are designed to work together. (ie. The intake and heads are port matched while the cam is designed to take full advantage of the two, depending on your HP and torque range.) Check out edelbrock.com for all the specs. You can do all this and stick with the Holley truck avenger carb, which is aslo what I'd do if you don't opt for fuel injection.
  17. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    AFAIK you can use Vortec heads (along w/ any other SB head) on a 400. You just have to drill the steam holes. I have a 400 block in my truck and the stock 350 heads. I wish I knew that they were drilled...the P.O. put it in.
    With the vortec heads (which are 64cc) and 5.7 rods you will have a hard time finding pistons w/ less than 10:1 compression. With the stock heads it isn't as much of a problem because you don't need such a big dish.
  18. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    What does everybody think is the best camshaft for low end power in a stock sbc 400 with headers and K&N airfilter?
    Mike.
  19. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Man this post is all over the place /forums/images/icons/tongue.gif. Well I will trade you my 350 for your 400 any day /forums/images/icons/wink.gif. If I'm building a 400 for a truck... I would rebuild the lower half and use either 5.7 or 6" rods depending one your preference. I personally like to keep all my rings in the traditional spots beacause IMO it is easier, but the 6" rod works fine. I would look for a good cast iron head for up north here, another opinion. I still feel that the iron is better duarability wise then the alum here in the crazy conditions of the north, but alum heads work for many people. The other plus of staying cast iron is they are cheaper.. for about 5 to 6 bills you can get SR Torquers w/ a 2.02 intake valve or the vortecs. I'd suggest a 3 angle valve job on the vortecs, or a VJ and some pocket porting on the SR's. Bothe heads with a 252-258 cam should net you about 300-325 hp and bset of all 420-450 ft lbs of torque up to 4000 rpm /forums/images/icons/cool.gif Top it with a Holley intake and I would use a tweaked quadrajet so you get enough fuel for this beast or go with a quad off one of the 455 cars, or the 472/500 caddys. They flow about 800cfm and work awsome. Quad is the only carb I would recomend using with the angles you will see out in the Badlands. There is my $.02
  20. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    The 400 is a great motor for your k5 for two reasons:
    1. It's as much stock displacement as you can get in a 'light' 500lb small block.
    2. It delivers great bottom end torque to get you moving off the line or crawl slowly over obstacles.
    The 400 would not be a good choice for trying to get high rpm hp/tq numbers from unless you want to get really spendy on the rotating assembly with all forged equipment. This is due to the longer stroke.
    The 400 is a great platform for making big hp/tq numbers at low rpm though, cast Speed-O-Motive stroker kits can put you in the 500hp/500lbft under 5500 rpm with a focus on RV. I recently built the above with a small Comp Xtreme 4x4 cam, lightly matched/pocket ported 1.95/1.5 cast iron smog heads with stock intake and exhaust and a Q-Jet (in other words - totally corked up!) . With 3.07 gears and 33's the truck leaps off the line, climbs hills relentlessly and gets much better gas mileage than my warmed over 350 that it replaced due to the torque. I'm sure many people will tell you the same with their stock 400's as well.
    Due to the fact that a cast 400 rotating assembly doesn't rev high, you really can't take advantage of a big carb and big valves like you can with a 350 which lends well to high rpm. Small valve heads will taper off around 4500 rpm but make tremendous bottom end, good vacuum and great mileage while larger valve heads lose a little on the bottom and vacuum but rev up to 5500 nicely. I used 350 heads and drilled the steam holes (a must) and it wasn't difficult so choose a head you like. I'd agree on the recomendation to get a good air gap high rise dual plane manifold and headers as it will make a big improvement.
    If your looking for more, you could spend the money on a forged assembly but it might be cheaper to either build a high rpm 350 or move to a big block. Good luck!
