400 SMALL BLOCK
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smp, Dec 9, 2000.
  1. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    How do you identify a 400 small block from a 350???
    [​IMG] SMP
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    One way are the three freeze out plugs on the side of the motor. .....so I'm told, All small blocks have 2. The best way is to get the casting numbers off the back pad on the block (drivers side)or the Identification numbers off the front pad under the alt. then run em. Also I believe there are differences in the heads (steam holes). the motor may have to be apart to ID that however......js
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    all 400 have 509 cast in to both sides of the block. upside down about 4/3 of and inch high by the boss for the ft mounts. Not all have three freeze plugs though. If you look at the balancer it not unaform like the rest of the sb.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  4. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    400 crankshaft should be externally balanced, 350 internally.
    Watch out for weights!!!
    Balou
    "Size DOES matter!!!", said the girl last night.
    http://www.balou.coloradok5.com
  5. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    The 3 freeze plug per side identifies a 4 bolt main 400, which was only available from 1970-1972 in cars, not trucks.
    The 400 was available in trucks from 1975-1980.
    ken
